Home > Technical (L322) > Quirky Starting |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
I seem to be suffering the same starting problem, but have never heard of the washers trick.
18th Feb 2018 4:43pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3082 |
Our 2012 has been doing this on and off since it was new.
18th Feb 2018 4:49pm |
westminster 62 Member Since: 03 Oct 2017 Location: essex Posts: 20 |
My 2012 4.4 tdv8 is exactly the same, have just had a new battery fitted, went to start it today and just kept on clicking, tried the wipers and it started, really weird, i am going to phone my local range rover specialist tomorrow to see if they have heard of this. |
18th Feb 2018 6:05pm |
It's quite a common fault on the 4.4 TDV8...
18th Feb 2018 6:19pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
I wonder if it1s a cold start thing? I have a 2011 SE when I press the start button the engine turn`s once then turns over and starts? It would appear that by turning the engine it moves the oil around which is cold and thick then starts the car don`t have the same thing when it`s warm.
18th Feb 2018 6:20pm |
Tinman, that's a different fault altogether by the sounds of it.
18th Feb 2018 6:22pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1375 |
My experience of the scenario of pressing the starter button and getting just a click sometimes, when battery fine, was that the starter motor was faulty and needed to be replaced, as others have said it seems a common fault. The button itself can also be faulty, but with that there is no click. Only Range Rovers since 1988 |
18th Feb 2018 6:44pm |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
I just wonder if all these starter motor problems are real. There is another relay in the starter circuit and I just wonder if it is that one we hear clicking. My gut feeling is that it is software related.
18th Feb 2018 8:23pm |
Ours is the same, the starter works perfectly when it does start.
18th Feb 2018 8:27pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
My p38 had a similar issue or on the face of it it was - random not starting but when it did it was fine changed the starter a couple of times in the end I put a new cable from the battery to the starter just doubled it up never had a problem again.
18th Feb 2018 8:40pm |
David,
18th Feb 2018 10:05pm |
I did but couldn't get them unfortunately. They were replaced by Land Rover under warranty so the originals had to be returned to LR by the dealer.
18th Feb 2018 10:13pm |
Makes me wonder if the act of replacing the starter motor is what sorts it out for a while?
19th Feb 2018 8:33am |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 |
can confirm it works on the 3.6 TDV8 2010MY Current Vehicles :
19th Feb 2018 10:58am |
