![]() | Home > Technical (L322) > Quirky Starting |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
This is the circuit diagram and as far as I can make out the start switch energises the junction box ignition relay via the CEM (providing all the CAN signals are good to go). From there it goes to the ECM and I'm guessing that the ECM energises the starter solenoid but from the diagram this appears to be via the alternator (generator) which seems a bit wierd.
There is far more to it than above but it seems the ECM plays a big part in it.
Let me say at the outset I'm not a conspiracy theorist......... but...
gotters Member Since: 15 Aug 2015 Location: London Posts: 41 ![]() ![]() ![]() |
Just searching and found this thread as my car has started exhibiting this exact behaviour, it's also the 2012 4.4 TDV8
jamesg25 Member Since: 07 May 2020 Location: Warwickshire Posts: 24 ![]() ![]() ![]() |
I’m also experiencing a similar issue with my 2012 4.4TDV8 - tend to find it won’t start after a it’s warm/been on a run. Have also read fault codes and found nothing that relates to the starter. Would be interested to know how you get on (and will be trying the windscreen wiper trick in future...) |
mine ended up being lent to the main dealers top technician to drive home/back in the evenings so he could see the problem for himself and diagnose on the spot when it happened, took him a few days and he liked the problem but was frustrated at how hard it was to track down.
