Home > Maintenance & Mods (L322) > Water draining from rear screen when top boot opened
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Just wanting to find out if this is a design feature - after/ during rain, when I first open the boot, if I don't wait 15s with the boot at 45 degrees (to ensure that the water pours on the ground) then water empties from the nearly horizontal rear screen onto the rear parcel shelf. Does anyone else suffer from this feature ?
Post #46879 21st Jan 2011 12:43pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Yep, reckon it's a design fault. I do the same as you, open half way, wait for water to run off, then fully open it. I used to end up with water on the parcel shelf aswell (still do if I'm in a rush!!).
Cheers Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #46880 21st Jan 2011 12:50pm
only done this once when i opened it very fast and got a puddle on the self, but if you open and lift normally letting the struts do the work then the water runs down the channels on each side.
Post #46881 21st Jan 2011 12:50pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Mine also does this.
Gone - Range Rover Supercharged 2006
Post #46900 21st Jan 2011 2:38pm
Vogue
same here
Post #46903 21st Jan 2011 2:59pm
The water gets trapped between the glass and the frame.
I wonder if filling the gap with black silicon would cure it
Post #46921 21st Jan 2011 5:01pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
I think it puddles on the panel underneath the spoiler at the top. I doubt you can do much to stop it as it probably goes in from the roof when driving..
Post #46940 21st Jan 2011 7:27pm
SteveMFr
Site Sponsor
Mine too. PITA.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #46979 22nd Jan 2011 12:15pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
mine does it also but if its collecting under the top spoiler panel could this be affecting the rear view camera i.e water logged inside or something onto no6 Range Rover
Everyone needs a hobby
Post #47104 23rd Jan 2011 1:32pm
Hang on, are you saying the water drips from the inside of the glass as if it has collected at the base of the top tailgate when closed?
If so, then it might signal a problem with your rear washer motor, mine failed and started leaking water down the inside of the glass, which I then noticed when I opened the top tailgate and it would then drip into the rear of the car and on me! Discovery 4 HSE
Post #47139 23rd Jan 2011 4:50pm
another conspiracy theory.. Laughing
Post #47148 23rd Jan 2011 5:07pm
SteveMFr
Site Sponsor
Bit confused... The rear wiper motor has a washer line connected to it and passes the washer fluid through the hollow wiper shaft to a hose on the wiper arm. The seal on this failed for you and the water dripping on you was actually washer fluid?
Mine is def rain water. No washer fluid smell and it only happens after a rain. And the with amount that comes out on both sides (outside not inside, tho) my washer reservoir would be empty in no time.
I have been meaning to check where it comes from. Aside from being a PITA, I'm also worried it could be collecting in the hollow bottom portion of the tailgate. And I've read about corrosion at the bottom corners of the upper tailgate more than once... Shocked
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #47211 24th Jan 2011 8:20am
VaguelyVogue
The water is all outside of the glass ! It must be collecting somewhere in the high level brake light cover assembly and then coming out when the boot lid is lifted - two streams of water (not washer fluid) from each corner of the boot lid.
At least it's not just me experiencing the issue !
Post #47223 24th Jan 2011 9:28am
its obviously a design fault but its not a big problem...
Post #47226 24th Jan 2011 9:36am
