![]() | Home > Wheels & Tyres > Wheel options? 20 21 22" |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
IMHO, 20" with 255/55 tyres are probably the best combination. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
With each drop, you’ll get a little more comfort - but a little more roll on roundabouts and corners.
TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210 ![]() ![]() ![]() |
20" is best for comfort and looks like it's meant to be. 22's are harsh and more likely to suffer pothole damage, and some might say they look too big. |
Nelzuk Member Since: 06 Feb 2018 Location: Warrington Posts: 14 ![]() ![]() ![]() |
Thanks for the replies chaps, I must say I would like to hang on the 22s as they do look great.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
Check your pressures in the 22's, I have got both 22" and a set of 20's with off road tyres - the 22's are fine as long as they are not overinflated - I run mine on the light load pressures and they are fine. You don't need the higher pressures unless you are fully loaded with 5 people and luggage. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Early 405’s suffer with suspension issues so make sure the dealer gets it right for you otherwise you will be driven MAD by rattles, knocks and a floaty feeling ride! If you need to pay for these then its VERY EXPENSIVE!!! |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Hi you may have read my later thread and issues I am hav8ng with some new Pirelli’s. Out of interest is your car on Pirelli’s or contis ? Regardless definitely agree regarding ensuring right pressures. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
Hi , I'm on contis. I have had the car in this week and had some bits replaced and it now drives great, out of interest whats PSI for light road use? |
33 psi front 36 rear. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1250 ![]() ![]() |
Daft question
ahbeddoe13 Member Since: 05 Mar 2018 Location: Cardiff Posts: 6 ![]() ![]() ![]() |
On my sport I was advised by a LR Master tech to change my tyres (when due) to a 275 45 20 instead of a 275 40 20. as it was a much better ride. It also fills the arch more which could work for the 22's although I have not tried that with my 405........ it could make it wallow a bit more.
Some other threads already - I run 275 40 22 Conti Winters
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
the 405 suspension is tuned to run the 22" rims, the 322 is not. It was only ever meant to run 20", which is why the ride might seem harsher on 22" in the 322 than it would on the same rim combo in the 405.
