Home > Maintenance & Mods (L322) > L322 Td6 06 - Facelift 2010 - Indicators Stopped Working |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1374 |
Do the wing indicators work ?
9th Feb 2018 5:38pm |
PaulCee Member Since: 31 Oct 2014 Location: UK Posts: 18 |
Yes the wing indicators work, as well as the side lights and headlights. Everything else works, just the front indicators have stopped working.
9th Feb 2018 5:47pm |
Ok. I’ll dig out the wiring diagram to get the right pin for the indicator feed to the unit and you couldsee if it’s getting 12v. signal.
9th Feb 2018 5:52pm |
Thanks for the help.
9th Feb 2018 7:46pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
The other way I believe to drive the front indicators on a 2010 facelift is to use a standard automotive relay driven from the side repeater if they have taken this route perhaps the relay(s) have failed. |
9th Feb 2018 7:52pm |
I am not the best when it comes to electrics. I was thinking though if I could not find a solution that I could maybe drive them from the side repeaters. Not sure how to test the relay either but I think I know someone that will help.
9th Feb 2018 8:12pm |
If you feed the wire for the indicator with 12v, it should light up.
9th Feb 2018 8:44pm |
I’ll try to grab some pics of the relay wiring of mine tomorrow, I didn’t do the face lift but the previous did I think with advice from Cam-Tech. |
9th Feb 2018 8:51pm |
Hi,
11th Feb 2018 7:48pm |
