Home > Technical (L322) > reversing camera
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
reversing camera
can anyone enlight me on the picture quality of the reversing camera.
mine is grainy all the time even in daylight conditions
just tried a RRS and the reverse camera quality is perfect..
am i expecting too much or do i have a faulty camers
help would be great
Post #46732 20th Jan 2011 12:10pm
Paulo
Could it be something as simple as the camera lens needing a good clean..... Question
Post #46737 20th Jan 2011 1:16pm
nbunney
I have found, in general, that they are not very good.
Post #46747 20th Jan 2011 2:11pm
iancollins
camera lense cleaned just really grainy like a bad picture on tv
Post #46772 20th Jan 2011 3:34pm
if its in the dealers at the moment can you not ask them to investigate..
Post #46773 20th Jan 2011 3:40pm
iancollins
yep
i've sent them an email but i know what they will say
"it's part of the character of owning a range rover"
just thought i'd try and get feedback to see if this is normal or i have a faulty camera
Post #46782 20th Jan 2011 4:06pm
i suppose that will be their response.. Neutral
Post #46783 20th Jan 2011 4:08pm
My camera is faulty when reversing , going into the dealers shortly to get repaired , common fault so i have read elsewhere on some models Thumbs Up
Post #46787 20th Jan 2011 4:31pm
iancollins
mick
what is the problem with your rev camera ???
poor quality or doesn't work
Post #46794 20th Jan 2011 5:38pm
daveo
hi the early ones were cmos and are not that great low res under 300 lines, then they went to ccd (charge coupled device) this gives a far better picture 420 lines and now on the 2010 its 520 and above giving you a very good picture with the option to zoom and still keep a good picture but before you rush on to ebay the later cameras will not work as they have 4 pins and signal opposed to the old ones having 2 pins and the signal V8 facelift Range Rover Autobiography 22" wheels.
Post #46796 20th Jan 2011 5:54pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Is there a cheaper alternative to paying GBP400 for a new reverse camera from LR that isn't that good in the first place?
If its not possible to use other camera brands, can we buy direct from Connaught Electronics Limited (CEL), the makers of the FFRR reverse camera? '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #46843 21st Jan 2011 6:00am
@ iancollins , sometimes it works other times it won't , and sometimes when it works its distorted and the picture is hazy and grainy like a bad reception .........
Post #46847 21st Jan 2011 9:07am
iancollins
mick
just like mine !!!!!!
Post #46862 21st Jan 2011 11:43am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
and mine, intermittent, have had a good look all round. Goes in for a service next fri, have asked them to look at it. It seems to me to be a loose/faulty connection somewhere. Just when i give up hope it sparks back into life. If it is working when i next use the beast it then fails......
Post #46912 21st Jan 2011 5:27pm
mercuryf1
managed to solve my reverse camera woes today without having to pay 400pounds to LR!
Went to a car accessory shop here in Malaysia. There was an array of cameras to choose from - ranging from 30 GBP to 200 GBP. What was great was there is no need to install an extra reverse cam screen. The image comes through to FFRR front touch screen!
Fitting took an hour the old faulty camera had to be removed from the original plastic casing to be replaced by the new unit. Plug and play! now I can SEE where I am reversing into now!
I opted for the expensive model as it captures a super-Wide image as well as has infra-red capability. Made in Korea, comes with a 2 year warranty! I will post some pics when I have more time. '01 1.8i Freelander. Grey/ grey
Post #47644 26th Jan 2011 4:23pm
