![]() | Home > Maintenance & Mods (L322) > Rear washer...no washing cos there is no liquid! |
gingerbiker Member Since: 06 Dec 2010 Location: North Yorks Posts: 26 ![]() ![]() |
The rear windscreen wash wipe is failing to do anything other than scratch the window today as there is no water squirting out. Any solutions/ common faults. The water bottle is full. It's not frozen.
The pipes run along the roof - they could be frozen. Do you use propper anti freeze/screenwash?
Blocked nozzles? It's a common problem. If left unfixed it can lead to the motor filling with screenwash fluid. Fairly poor design really.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
I sent my car into LR for a same problem naively thinking it would be covered by the LR approved warranty. Sadly it was not and I paid about �20 to have the rear jet and one way valve cleaned.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Mine is playing up- if I push the stalk forwards, I can hear the motor running intermittently, but no water coming out of the back. Anyone else had this? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Noddy
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic884.html
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Can anyone point me in the direction of the NRV? |
Cheers. Mine sounds electrical though. If I hold the stalk forwards, it wipes and I can hear the washer bottle motor running intermittently. Sort of a stop start, then it stops altogether. I'm thinking its the contacts in the stalk itself. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60 ![]() ![]() |
You can buy the valve from you dealer for only �5...probably costs about 10p to make.
Just been out to check mine and the rear wiper arm is solid with corrosion. Where is the cheapest place to get a new one and what's the part number? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
You can try ebay but I reckon it would be quicker and easier and not much more just to get one from your local dealer. Discovery 4 HSE
I fitted a new rear arm a couple of weeks ago, cost around �20.00 from LR |
No idea my post would create such a flurry of responses; will have a play tomorrow.
