Home > Maintenance & Mods (L322) > Rear washer...no washing cos there is no liquid! |
gingerbiker Member Since: 06 Dec 2010 Location: North Yorks Posts: 26 |
The rear windscreen wash wipe is failing to do anything other than scratch the window today as there is no water squirting out. Any solutions/ common faults. The water bottle is full. It's not frozen.
19th Jan 2011 9:57pm |
The pipes run along the roof - they could be frozen. Do you use propper anti freeze/screenwash?
19th Jan 2011 9:59pm |
Blocked nozzles? It's a common problem. If left unfixed it can lead to the motor filling with screenwash fluid. Fairly poor design really.
19th Jan 2011 10:09pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
I sent my car into LR for a same problem naively thinking it would be covered by the LR approved warranty. Sadly it was not and I paid about £20 to have the rear jet and one way valve cleaned.
19th Jan 2011 10:14pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Mine is playing up- if I push the stalk forwards, I can hear the motor running intermittently, but no water coming out of the back. Anyone else had this? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
19th Jan 2011 11:49pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Noddy
20th Jan 2011 7:51am |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 |
http://www.fullfatrr.com/forum/topic884.html
20th Jan 2011 8:40am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Can anyone point me in the direction of the NRV? |
20th Jan 2011 2:41pm |
Cheers. Mine sounds electrical though. If I hold the stalk forwards, it wipes and I can hear the washer bottle motor running intermittently. Sort of a stop start, then it stops altogether. I'm thinking its the contacts in the stalk itself. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
20th Jan 2011 6:15pm |
CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60 |
You can buy the valve from you dealer for only £5...probably costs about 10p to make.
20th Jan 2011 7:30pm |
Just been out to check mine and the rear wiper arm is solid with corrosion. Where is the cheapest place to get a new one and what's the part number? |
20th Jan 2011 9:47pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
You can try ebay but I reckon it would be quicker and easier and not much more just to get one from your local dealer. Discovery 4 HSE
20th Jan 2011 10:20pm |
I fitted a new rear arm a couple of weeks ago, cost around £20.00 from LR |
21st Jan 2011 5:04pm |
No idea my post would create such a flurry of responses; will have a play tomorrow.
21st Jan 2011 6:41pm |
