Home > Technical (L322) > AUX input on TV ?
4rovers
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
AUX input on TV ?
My vehicle is a 2002, when scanning the channels I get an AUX selection, does anyone know where this aux input is?
Maybe I can put a dvd player on it or a digibox for digital TV.
Thanks for any advise
Post #46741 20th Jan 2011 12:55pm
dan_uk_1984
You can upgrade your TV module to be Digital...
The Aux input is S-Vid which in itself isn't so bad - however the audio input is Mono - so not really suited for DVD players etc.
A better use of the Video input is a reversing camera - a relatively easy mod, quite cool as it automatically switches over when you select reverse gear.
Dan
Post #46743 20th Jan 2011 12:59pm
4rovers
Hi,
thanks for the info, do you know where the input connections are physically so I can give it a try please?.
Thanks
Post #46750 20th Jan 2011 1:29pm
4rovers wrote:
Hi,
Thanks
in the boot..
@DAN...when selecting reverse does the screen have to be on nav or does it change when on radio..
Post #46752 20th Jan 2011 1:43pm
4rovers
ooooh dear,
scarey, there are lot's of connections in the boot, I just need to know what ones I need to connect to, if someone can help.
Thanks
Post #46762 20th Jan 2011 2:09pm
theres loads on this subject on the forum , do a search and have a good read ...
Post #46764 20th Jan 2011 2:18pm
dan_uk_1984
4rovers wrote:
ooooh dear,
There are lot's of connections in the boot, I just need to know what ones I need to connect to, if someone can help.
Thanks
Short of someone actually coming round to your house and doing it for you, I think you're kinda there...
As Scary said, the connection is in the boot, on the left hand side. As I said, it is a yellow S-Vid/Composite plug.
You should download a copy of the Workshop Manual - this will provide you with all the tech info, as well as locations of things for reference.
I "think" it comes on automagically - ask Daveo, he's done it.
D
Post #46793 20th Jan 2011 4:22pm
SteveMFr
Site Sponsor
You first have to add the automagic Laughing
You either buy a kit with the cam/relay/harness for around GBP150 or you buy an NTSC cam on ebay for GBP25 and a relay from an auto parts store for GBP5 and make your harness. This cam works very well in a RR, BTW, although you do have to file a little metal inside the number-plate light slot Shocked .
The cam is wired into the TV module:
Pins 13 and 14 on the white plug are vid in. Pin 17 on the blue plug needs ground to switch, so what you do is this:
The coil in the relay is energized by the reverse light (pins 85 and 86 on the relay) and closes the contacts (pins 30 and 87) switching ground to the vid module. You can add the manual switch to gnd like this guy has too. That way you can see if someone is following much too closely. Or watch as you're being rear-ended at a traffic light. Or add another relay and switch between vid sources (such as a DVD player). Or...
Female connectors are avail for little money at BMW. I posted the PN a few weeks ago - I'll leave that as your search job. Whistle
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #46828 20th Jan 2011 8:58pm
4rovers
Exceelent,
thanks Steve, all the information I need, best go make it work then.
Thanks again.
Post #46893 21st Jan 2011 2:26pm
Jsb
http://www.fullfatrr.com/forum/topic4138.html if you dont want to mess around with pins for the wideo feed.
Post #46909 21st Jan 2011 3:57pm
