![]() | Home > Maintenance & Mods (L322) > Electrical faults with L322 (Head Unit and Sound, Locking) |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
ive had the same random stereo issue with my 03 td6 , switches itself off after 20 mins then sometimes goes for 2 hours plus without any bother , buy a clamp meter pal , not dear these days , it will help you find the battery drain easily enough |
urquattrogus Member Since: 02 Feb 2018 Location: Essex Posts: 34 ![]() ![]() |
I might do that.
water gets in there pal , common as |
nar53 Member Since: 04 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
Loving that user name. I had an 82 urquattro for about 10 yrs & loved it. Only sold it because we decided to move to France but I seriously wish I still had it. Good luck with the water ingress. |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi you say you have intermittent loss of power to head unit I had exact same issue it turned out to be a faulty nav on the move module fitted I removed this after 6 months of investigation and checking every module in the rear compartment also.
so you unplugged the NAV unit ? mine doesnt work anyway |
No not the Sat Nav unit I had a nav on the move module fitted you will know if you have one fitted because you can watch tv or dvds on the headunit when driving. If so disconnect it this could be faulty. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
I don't even know if the dvd works pal , have to check , thanks for the tip |
