Home > Maintenance & Mods (L322) > Brake time again
Sandyt
Brake time again
Brakes are low again just wondered what people do I always change discs and pads not just pads probably a bit of overkill but I just feel that for a couple of hundred quid why not?
Post #467440 5th Feb 2018 2:59pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Changing the discs each time with the pads is definitely overkill unless they are severely lipped / worn or out of true or corroded so the pads aren't working on their full surface area. .
Even for somthing as heavy & fast as a SC I would have thought every 2nd pad change would be fine.
I'm just changing them on our recent acquisition 2006 3.6tdv8 at 123,000miles - but they were working fine despite the 3mm lip each side & masses of rust.
The pads are less than half worn, so whoever changed them last was being rather lazy as they couldn't have been much better then Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #467441 5th Feb 2018 3:16pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Depends on how worn the discs are. If within tolerance then they are left on the car.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #467443 5th Feb 2018 3:27pm
I do mine every second set of pads. Don't need doing any more often than that. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #467454 5th Feb 2018 6:29pm
