Home > Technical (L322) > How many EGR valves.? Confused
Jonricevogue
United Kingdom 2012 Range Rover Vogue TDV8 Bonatti Grey
Hi guys
I have a 2011 61 4.4 tdv8. Needs a new EGR under warranty. Now after reading a few forums people are saying there are two EGRs on this vehicle.
The garage who is replacing it says there is only one, in the centre of the V!
I called Land Rover Preston they said there are two EGR valves,
I called Land Rover Liverpool who took my reg and said there’s only 1 EGR valve.
Who correct? Is there 1 or 2 EGR valves.
Thanks in advance
Post #467421 5th Feb 2018 1:02pm
according to the WM there is only one ,
The combined EGR valve motor and cooler is located between the V of the cylinder banks. The cooler side of the EGR is
connected to the vehicle cooling system, via hoses. The inlet exhaust side is connected to the exhaust manifolds on each side via a metal pipe which passes from each turbocharger and passes across the rear of the engine. The exhaust gas passes through the cooler and are expelled via the actuator and a metal pipe into the throttle housing. The EGR valve motor is a DC stepper motor with integral position sensor, which is controlled by the engine control module (ECM). The ECM uses the EGR valve motor to control the amount of exhaust gas being recirculated in order to reduce exhaust emissions and combustion noise. The EGR is enabled when the engine is at normal operating temperature and can operate at engine idle or under all part load operating conditions, in both the transient and steady states. EGR only operates in mono-turbo mode and is shut-off before bi-turbo mode is initiated.
Post #467428 5th Feb 2018 1:13pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
The 3.6 TDV8 has two but I'm sure the 4.4 TDV8 has one.
Part no EGR Valve - LR033373
It is twice the price though. Very Happy 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #467432 5th Feb 2018 1:18pm
Jonricevogue
Great thanks guys.
Bit worrying Land Rover Preston thinks there are two.
Post #467436 5th Feb 2018 1:31pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
It's only 1 egr on the 4.4 because it has sequential turbocharging rather than the parallel set up of the 3.6.
ie only 1 turbo is working to feed both banks of the v8 at the low load / revs when the egr valve does anything.
On the 3.6 each turbo is feeding 1 half of the v8 all the time, so an egr is required for each bank. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #467442 5th Feb 2018 2:23pm
Jonricevogue
Thanks Paul 👍
Post #467445 5th Feb 2018 2:38pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
2011 still under warranty??? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #467636 7th Feb 2018 8:30am
Jonricevogue
I didn’t buy it from Land Rover. it is under warranty from the garage I bought it.
It’s a lovely car, previous dr owner. Full service history by Land Rover, only done 55k.
I was going to ask about warranties? What’s the best used car warranty available to me? I understand these cars can throw some gremlins at you .
Cheers
Post #467650 7th Feb 2018 11:33am
