![]() | Home > Technical (L322) > ARM-AIRBAG Fault |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
off chance that it might work: Check your battery connections are tight. I had faults come on and tightening the cables on the terminals cured this. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I had na srs fault showed different to yours on the 11D tool it eventually went after a full battery charge - might be worth charging it overnight |
