Home > Maintenance & Mods (L322) > Possible Turbo issue sounding like a siren!
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys I recently noticed a police siren like noise coming from engine only at 1500 to 2000 rpm and fades as I increase revs I haven’t noticed a loss in power and no black smoke could it be a split or loose hose? Any ideas or advise much appreciated and if it turns out to be a knackered turbo can anybody point me in the right direction to either have mine reconditioned or who to buy a recon unit from.
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #455119 24th Oct 2017 9:13am
i'd check out the hoses first...if possible take them off and look on the underside and inside.. ... - .- -.
Post #455120 24th Oct 2017 10:11am
jaysta10k
This is first port of call cheers Stan. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #455121 24th Oct 2017 10:17am
jaysta10k
This is s bizzare one guys still got the high pitched siren like sound when car is ticking over its low pitched then when I give it some throttle it get louder and more high pitched but fades off at about 2000rpm any ideas please. Checked all hoses and air filter box etc all good
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #466814 1st Feb 2018 9:43am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I think your turbo is on the way out.
My car had the police siren sound for a few years, but ultimately I had to replace my turbo.
New turbo, no siren noise.
Post #466853 1st Feb 2018 5:31pm
Paul thornton
My bmw 530d began sounding like a police siren. Indeed it was the turbo failing but I just left it and traded the car in!
Post #466856 1st Feb 2018 5:53pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Cheers
Jay
Is it a Td6?
Post #466911 1st Feb 2018 11:55pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Sounds like turbo is failing Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #466930 2nd Feb 2018 9:18am
jaysta10k
Yes its a TD6 but I have had no reduction on performance whatsoever car is running fine etc... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #467100 3rd Feb 2018 11:02am
rangie47
if you require a new turbo ,google best turbos Birmingham.
have used the myself and there work is excellent 2007 tdv8 se ,stornaway grey
Post #467221 4th Feb 2018 10:39am
jaysta10k
Hi guys this is a strange one I can hear the whining noise more so under revs only unto 2000rpm at the back of car near rear tyre could this be diff related any ideas the sound is more noticeable at rear of car than in engine bay after more investigation.
cheers
jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #467293 4th Feb 2018 6:26pm
jaysta10k
more noticeable at rear of car than in engine bay by sounds of it Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #467294 4th Feb 2018 6:27pm
GDM
Our Td6 was exactly the same. Noisy up to about 2000rpm, then fine. I was convinced at one stage that the whining was loudest around the n/s rear wheel and thought it might be the cill mounted fuel pump. I took it to my local garage for them to listen, we put it over their pit, ran it up to 1500rpm and put a long screwdriver blade on the turbo, and with the handle to your ear you could clearly hear it whistling.
I got a reconditioned turbo from Universal Turbos, who had recently taken over CR Turbos, who I had used before and who were excellent. After fitting, the turbo dumped loads of oil into the engine. I called Universal Turbos who said that it couldn’t be faulty as they were all tested, they blamed the breather (which I had already replaced), and then accused the garage of using sealant on the gaskets. Eventually after speaking to the garage they replaced it under warranty.
I have since replaced the turbo on our 5 series BMW and I got a reconditioned turbo from Essex Turbos. They were very helpful, and provided a really good service, including supplying new feed and drain pipes.
Post #467366 4th Feb 2018 10:47pm
jaysta10k
Cheers for info really strange as doesn't explain why we can hear the whining siren noise at rear wheel area more so than in engine area! but when sat in car you can hear it in drivers seat
Previous Cars
BMW M3 Carbon Black
Post #467405 5th Feb 2018 10:39am
GDM
Yes, it’s very odd how the sound seems to be coming from the rear wheel area. Try the screwdriver trick.
Post #467489 5th Feb 2018 10:41pm
