Home > Maintenance & Mods (L322) > 2002-2005 M62 PCV Valve - then it went a bit wrong! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I'm not sure on the BMW parts as the M62TU engine in some of the BMWs have a cyclone behind the timing covers which may be instead of the one for the PCV at the rear but looking at real oem link below it all looks the same
29th Jan 2018 9:53pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Thoughts on these? eBay item eBay Item No. 152342226526 Current stable:
29th Jan 2018 10:46pm |
They look alright, i have red cam covers so i cant talk !
29th Jan 2018 11:53pm |
Ok my buddy is just finishing building his house so he said it will be a month or so. In order to preven the random eml thinking I will just change the hoses for now well the top ones for certain as they’ve split. Is there any way to do the small one with pcv in place or are you saying it will snap? How would you clean the drain hose? Massive pipe cleaner? Does this need to come off for cleaning or could I leave it in place and disconnect at the sump? Current stable:
30th Jan 2018 7:10am |
The pipe wont snap but the plastic end on the PCV valve will most likely snap off in the end of the little pipe and then you can just remove it. If you are just going to do the pipes and not the valve then you wont need to disconnect the small one.
30th Jan 2018 8:22am |
Can I do the otherway take the lid off the cyclone(can you?) and blow compressed air down?
1st Feb 2018 5:04pm |
If you go back to Saints how to it shows you the pipes to change, you are only changing the two big pipes shown in saints photos ( the blue ones on the attached) and the PCV Valve if you do that at the same time.
1st Feb 2018 6:52pm |
does the cyclone come apart easy so i can spray in it? is there a problem not disconnecting it from the sump and blowing the crap into the sump the doing an oil change a bit later? Current stable:
1st Feb 2018 10:05pm |
I don't think the cyclone comes apart but i may be wrong. It is only one bolt to take the pipe off the sump but i cant remember is it above the oil level or not.
2nd Feb 2018 8:13am |
ok great does the bottom little pipe go bad? just don't want to blow into it and it disintegrates Current stable:
2nd Feb 2018 9:22am |
How much pressure does the system generate? Basically did the top hoses but they are so fat I can only get one jubilee clip on. They are very tight. I gave it the beans and didn’t move at all.
3rd Feb 2018 9:41pm |
8th Feb 2018 1:10pm |
Bump on the dipstick / vacuum question - if I have very little / no vacuum is that good or bad! Current stable:
8th Feb 2018 9:52pm |
Sorry, I stopped getting notifications on this thread.
9th Feb 2018 1:16am |
