Home > Maintenance & Mods (L322) > 2002-2005 M62 PCV Valve - then it went a bit wrong! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Excellent stuff Saint .
18th Aug 2013 9:21pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
30th Nov 2017 9:27am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
If you have PCV problems/worries it is definitely worth a try - although I profess to be no authority on if it will work or not! |
30th Nov 2017 4:33pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
My pcv valve wasn't like that but i did try and take it apart after i changed mine when i had the inlet manifold off and the only way i could get that bit apart was with a hacksaw.
1st Dec 2017 1:02am |
ok - just a point these - is it just the diaphragm that packs up? if it is I may have a go with that more simple method first - or is there more tat goes wrong with them? with the hvac out and access mode in place can you access it ok?
23rd Jan 2018 11:48am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
Good to see you here Saint read many posts on Landyzone |
23rd Jan 2018 6:04pm |
You can see if you can just change the diaphragm but I couldn't separate that part without a hacksaw, the pipes normally turn to mush and the ridiculous tiny little pipe that feeds under the intake manifold will most likely break if you even look at it funny and is a bit of a pig to reconnect.
24th Jan 2018 5:55pm |
ok great - if I remove the cyclone only to begin with will that give an idea of the state of the rest? I don't even know that I have a problem its just I had both rocker cover gaskets fail and some say it can be due to this... Current stable:
25th Jan 2018 3:19pm |
Its easy enough to feel the pipes that run from the cyclone and to the top of the cam cover and pcv. If they feel like a durex half full of semolina then they need to be replaced.
25th Jan 2018 8:22pm |
Right mr chicken not sure if you saw my other post but today was very s**t potentially had a cable tie go into the engine praying a) it didn’t b) if it did it’s smashed to tiny pieces!
27th Jan 2018 11:26pm |
This is from above showing some of the symptoms of a faulty PCV, i have heard of an engine fail caused by pcv but cant remember the explanation but mainly you are potentially getting running issues and oil leaking.
28th Jan 2018 12:15am |
Sorry talking over two threads lol I will ask something different from this does the drain hose from the cyclone to the sump go bad too? Current stable:
28th Jan 2018 11:13am |
you are indeed, keep this one to your pcv woes, that the two drain pipes normally just get blocked, change the other 3 along with valve and clean / replace cyclone |
28th Jan 2018 1:56pm |
Hi holiday chicken - I have (I think) managed to rope my mate into this a little put off currently after rocker cover gate. He is a Bmw mechanic so has done it loads of times bit was going to ask if you know if the parts are the same lr/Bmw ? I imagine they all are but wasn’t sure if the sump drain would be? I have messsged Dan but he’s been rather quiet so was going to get a price from Bmw that’s all...
29th Jan 2018 9:05pm |
