![]() | Home > Technical (L322) > Kilometers to miles |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35489 ![]() ![]() |
pretty sure the only way is to change the cluster and even then the odometer wont be correct.. ... - .- -.
Blankone Member Since: 10 Aug 2016 Location: St Helens Posts: 21 ![]() ![]() ![]() |
Annoyingly this would seem the only option unless some clever person know a work around as it is a costly job, not to mention pulling the dash out and having to have the new cluster recalibrated with correct mileage including the othe ECU’s where it is stored. |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 ![]() ![]() ![]() |
So it's not Like a Mk 2 Disco where ( I think) you just pushed the (?) mileage knob in for a very long push, then? When I was looking for a Disco or RR, one of the Disco's I looked at had that, and the last MOT garage had recorded the km's reading as the mileage on paper and in the online records.
Don’t know about the disco but can’t find a similar option for the RR, I know the mpg can be swopped from litres to miles via the screen menu but found nothing to swop the recorded KLM’s to miles, have also called some mileage correction services and they don’t know either.............? |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
On mine I can go into trip computer then units and change to kilometres, it then displays mileage in kilometres and puts a digital readout of speed in kph in the middle of the speedo.
Hi Ian, from your response I think you have the full digital display cluster from 2010 onwards which unfortunately I don’t have, mine is 2009 so pre facelift and has a normal speedo with digital mileage recording...... |
