Home > Maintenance & Mods (L322) > Newbie and MPG per Tank
Skye08
Hi,
I have owned my TDV8 3.6 Vogue since early December and love it , coming from and X5 I knew there would be a difference in MPG however I am not sure if I have a problem somewhere.
When the tank is full the MPG to empty is around the 290 mark, I brimmed it yesterday it was showing 283 to empty, I drove about 12 miles and filled the tank up again this morning (took about £6) and now showing 280 to empty.
Prior to filling yesterday the dial was showing half and the trip was 113 miles for half a tank. The last few weeks has mostly been short city driving and giving it the odd blast which doesn't appear to make any difference.
I have had 30 on the motorway but mostly between 15-21 with normal driving.
Does this appear to be normal miles per tank? How many miles do you get to a tank when resetting at the filling station?
Thanks
Post #465375 21st Jan 2018 2:12pm
Closerthanmost
Mine is usually about 436 miles to empty when 100% full.
I assume it's based on mpg history as it was only about 400 when I first got it.
Post #465388 21st Jan 2018 3:14pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
around 460 odd for me when full
Post #465392 21st Jan 2018 3:20pm
Skye08
Thanks. It has been about the 290 mark since I got it.
Post #465396 21st Jan 2018 3:31pm
the computer works this out on previous driving history, for instance if you drive at 40mph for 200 miles and then fill up you'd get a bigger tank range .. ... - .- -.
Post #465397 21st Jan 2018 3:36pm
Baltic Blue
And a numb bum Rolling with laughter Rolling with laughter G reg 2.5VM Vogue Portofino red 1991- 1999
Post #465401 21st Jan 2018 3:58pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Mine will return 34mpg on a run down to London, but I don't even bother looking at what it does around town.
I will say I drive her very gently, and always fill up with Shell or BP diesel. On a run I set CC at 60 and then just glide wherever I'm going to. RPM stays around 1,500 and I get the best she can for MPG.
Post #465410 21st Jan 2018 5:08pm
GGDR
I just set the trip every fill and get to know what to expect from actual miles.
Greg Cheers, Greg
Post #465411 21st Jan 2018 5:13pm
Re: Newbie and MPG per Tank
No idea what that means but it's definitely an impressive stat.
Post #465431 21st Jan 2018 7:08pm
