Home > Technical (L322) > Loose mirror
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Loose mirror
I have a slightly loose mirror on the offside. Can somebody please tell me how to tighten it please?
The arm from the door is fine, it’s the mirror housing that’s wobbling slightly (hope this makes sense!).
Thanks in advance Thumbs Up
Post #465228 20th Jan 2018 12:12pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
On the lower side of the mirror housing where the puddle lights are, there is a round plastic plug with a small slit for a screwdriver to prise open. Inside there are 2 screws - these may be loose. Thumbs Up
Post #465266 20th Jan 2018 4:37pm
theres also a 'how to' in the wiki re loose mirrors... ... - .- -.
Post #465267 20th Jan 2018 4:40pm
kgeddes
Thank you Dolphinboy, just had a look and sadly I don’t see any plastic plug Question Wish I had though as that sounds like an easy fix! Thanks anyway Thumbs Up
Post #465270 20th Jan 2018 4:53pm
kgeddes
Thanks Stan, I looked at that earlier, shame the photos are missing. I was hoping I wouldn’t have to remove the door card and the mirror assembly for this...I’ll have another read Thumbs Up
Post #465273 20th Jan 2018 4:57pm
kgeddes
Does anybody know if I can remove the mirror cover/cap and if I can, is there a facility to tighten the mirror wobble there? As already stated the mirror arm from the door is fine. Thanks in advance.
Post #465320 20th Jan 2018 10:34pm
don't think you can ...you might be able to prise the mirror off a get 'in' that way..do a search for something like 'broken mirror' and see what comes up.. ... - .- -.
Post #465341 21st Jan 2018 8:18am
GGDR
Stan's right. I found out because my mirror got whacked by a passing taxi a few weeks back. The mirror glass popped out, there it was just hanging on the cables. I pulled over and it popped straight back in.
I needed CPR but the mirror was fine. I would try googling / youtube first.
And use one of those wide plastic trim removing levers:
http://www.carwingmirror.co.uk/user/produc..._16103.jpg
Good luck, Greg. Cheers, Greg
Post #465343 21st Jan 2018 8:31am
kgeddes
Thanks Stan & Greg, I found this on YouTube, hopefully there will be a tightening mechanism behind the cover, I’ll maybe have a go later today and report back.
Post #465344 21st Jan 2018 8:40am
nino_nino
this is what you'll find inside. Thumbs Up
Post #465348 21st Jan 2018 9:13am
kgeddes
Thank you very much for the photos nino_nino Thumbs Up
Do you know if it is possible to tighten the mirror in there somewhere?
Post #465364 21st Jan 2018 11:31am
nino_nino
this is the main metal casting that pivots, so i would assume this bolts must be what is holding outside plastic structure.
Post #465372 21st Jan 2018 1:00pm
kgeddes
Many thanks once again nino_nino Thumbs Up
I’ll report back when I’ve had a look...
Post #465376 21st Jan 2018 1:16pm
kgeddes
Finally got round to trying to tighten up the wobbling o/s mirror. Mirror cap came off no problem, tightened the bolts nino_niro highlighted but made no difference Big Cry
Anybody got any other ideas Question
Post #477639 6th May 2018 4:33pm
kgeddes
The complete mirror assembly is wobbling up and down as per the red arrow in this photo:
Post #477641 6th May 2018 4:38pm
