Home > Technical (L322) > HELP - PLEASE
colinwebster
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
HELP - PLEASE
Hi All,
Randomly my alarm went off today whilst outside the house??
I unlocked and locked the car and it went off again, then I noticed the suspension was lifting and lowering on it's own, inside the car all sorts of weird things are happening, gauges running up and down, engine and trans failsafes showing Hi/Lo light flashing, dis lights flashing, park brake/oil and ignition lights all randomly flashing, I disconneted the battery for a few minutes and its the same, all the random stuff stops when it starts up.
Any Ideas???
Its been perfect up to now, but had a screen fitted yesterday??
How long do I leave it disconnected to clear the ECU??
Thanks.
Post #465238 20th Jan 2018 3:34pm
GGDR
With the battery disconnected, Check it's voltage with a multimeter. Cheers, Greg
Post #465239 20th Jan 2018 3:41pm
colinwebster
The battery is Brand New at 12.8 volts (It's a month old)
Post #465241 20th Jan 2018 3:45pm
Do a hard battery reset, Disconnect the live & earth and touch them together...
Post #465243 20th Jan 2018 4:17pm
colinwebster
Thanks.
I’ve disconnected the battery. Left for 30 mins then shorted the leads. All seems ok at the moment. 😂😂😂😂😂😂
Bcm is dry.
Post #465245 20th Jan 2018 4:41pm
colinwebster
MM, after a while the alarm has gone off again, I noticed the front air suspension lifting at the same time, none of the other faults this time??????
Ive pulled the alarm fuse for a moment to see.........
Anyone else have these issues before???
Post #465247 20th Jan 2018 5:00pm
the bonnet switch is a common problem, clean it or disconnect it..... ... - .- -.
Post #465249 20th Jan 2018 5:04pm
colinwebster
Thanks Stan, the switch was disconnected when I bought the car, its still disconnected now, but it is in the area where the windscreen guys were ???
Post #465250 20th Jan 2018 5:05pm
you didnt mention the windscreen replacement in your original post..
theres an alarm sensor/light by the interior mirror and some other alarm stuff in that area so it sounds like they have possibly damaged something when they installed the screen.. ... - .- -.
Post #465255 20th Jan 2018 5:17pm
Paul thornton
If it's just had a windscreen fitted I'd be starting there.
I've seen it plenty of times where fitters cut through / shorted the wiring going to the rain sensor etc which will cause all sorts of issues.
It may even be leaking.
Post #465257 20th Jan 2018 5:21pm
colinwebster
Hi Stan,
"Its been perfect up to now, but had a screen fitted yesterday??" was in the post.
They finished the screen at 1400 yesterday and things have been fine until this afternoon, drove and parked the car a few times last night ???
Do you know what items are up there???? I thought the alarm stuff was in the centre light console in the roof????
Thanks for any help ??
Post #465259 20th Jan 2018 5:24pm
Paul thornton
There's loads of wiring running up both a pillar trims and there's also quite a few running to the light / rain sensor at the top of the screen and also running to the rear view mirror
Post #465263 20th Jan 2018 5:32pm
cant recall that in your original post , maybe your edit confirms my suspicions .... ... - .- -.
Post #465264 20th Jan 2018 5:34pm
colinwebster
Really Stan!! It was there probably edited some other grammar.
Post #465275 20th Jan 2018 6:05pm
colinwebster
I think you have mis read my post Stan,"Last edited by colinwebster on 20th Jan 2018 2:50pm. Edited 1 time in total" your reply was after 1600 hours so unless I'm mistaken the reference to the windscreen was in the original post. I have been a moderator on many forums over the years so Ill put your mistake down to professional pressure Very Happy Very Happy
Post #465278 20th Jan 2018 6:16pm
