![]() | Home > Maintenance & Mods (L322) > remaping for bioethahnol |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
Doesn't bioethanol have reduced lubrication properties compared standard pump petrol ?
vogue16 Member Since: 29 May 2015 Location: Angouleme Posts: 37 ![]() ![]() |
hi pawl
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I believe ethanol destroys rubber fuel hoses. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Sorry what is the purpose of this? If it’s to reduce running costs wouldn’t lpg make more sense as tried and tested?
I think it may be more to do what fuel is available in Vogue16s location ? Paul,
here bioethanol costs 0.59€/litre so even if my FF is not my daily car , if i can run it with bioethanol without any issues for the car ..why not? Current: L322 TDV8 4.4 |
Is lpg not so cheap? Current stable:
yes perhaps, but the cost for installing LPG is not the same.. Current: L322 TDV8 4.4 |
Ahh ok fair enough - well ultimately it’s up to you but lpg is pretty much tried and tested - bioethanol may be great but no one on head can really tell you I doubt... you may be pioneering something here! Current stable:
yes it seems no one tried ..
Lpg is still cheaper no? Pretty much tried and tested? Current stable:
hi guys
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
If it's not your daily car I wouldn't bother to be honest.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Bio-ethanol has only 70% of the efficiency of petrol so more needs to be burnt to achieve the same performance Bio-ethanol does not have the lubricity of petrol and burns much hotter; this may cause damage to the fuel system/injectors and spark plugs Pure bio-ethanol is very difficult to start in cold weather. Commercially available fuel containing bio-ethanol has a ratio of 15:85 petrol:bio-ethanol for this reason Bio-ethanol is pure alcohol and may well attack plastic or rubber connectors in the fuel system In short, don't do it |
