Home > Maintenance & Mods (L322) > remaping for bioethahnol
vogue16
France
hi guys
i have seen a land rover specialist who proposes to remap the FF ( 4.4 v8 petrol jaguar engine) for it can run bioethanol at 100%.
Have you heard anything about such modifiaction/remaping ?
any advice about that ?
thanks a lot Current: L322 TDV8 4.4
Post #463683 7th Jan 2018 7:17pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Doesn't bioethanol have reduced lubrication properties compared standard pump petrol ?
If it does, using 100% bioethanol could have a very bad effect on wear of valve stems / valve guides perhaps. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #463688 7th Jan 2018 8:18pm
vogue16
France
hi pawl
yes perhaps etahnol could have a bad effect on certain parts..
but perhaps not, that is the purpose of my post, tryiing to get some experience feed back if some guys have some. Current: L322 TDV8 4.4
Post #463824 8th Jan 2018 8:34pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I believe ethanol destroys rubber fuel hoses.
Post #464150 11th Jan 2018 11:40am
Danwilderspin
Sorry what is the purpose of this? If it’s to reduce running costs wouldn’t lpg make more sense as tried and tested?
If it’s performance with the gains youd get a remap intake and exhaust would probably do a better job and not mess the engine up Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #464175 11th Jan 2018 3:48pm
Pawl
I think it may be more to do what fuel is available in Vogue16s location ? Paul,
Post #464204 11th Jan 2018 7:34pm
vogue16
France
here bioethanol costs 0.59€/litre so even if my FF is not my daily car , if i can run it with bioethanol without any issues for the car ..why not? Current: L322 TDV8 4.4
Post #464221 11th Jan 2018 8:48pm
Danwilderspin
Is lpg not so cheap? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #464357 12th Jan 2018 11:40pm
vogue16
France
yes perhaps, but the cost for installing LPG is not the same.. Current: L322 TDV8 4.4
Post #464464 13th Jan 2018 8:58pm
Danwilderspin
Ahh ok fair enough - well ultimately it’s up to you but lpg is pretty much tried and tested - bioethanol may be great but no one on head can really tell you I doubt... you may be pioneering something here! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #464473 13th Jan 2018 10:09pm
vogue16
France
yes it seems no one tried ..
but i will not pioneer too far..
even if the running cost is very interesting there is too much dark areas.
i am not sure the jag engine is rerady to accept it, i can not find any information, i tried the jaguar forums and it is the same..
so i think i will just keep my ff stock . Current: L322 TDV8 4.4
Post #464930 17th Jan 2018 7:43pm
Danwilderspin
Lpg is still cheaper no? Pretty much tried and tested? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #464951 17th Jan 2018 10:25pm
vogue16
France
hi guys
some news about that, for those interested
apparently a company specialised in remaping here, remaped a L322 5.0L supercharged with success,and also a 4.4 with the bmw engine.
The cost is quite reasonable 495€..
it is a flexfuel remaping of the engine management, so you can use bioethanol or petrol as you want.
they guarantee to take your car back to origin if you want for free..
i am tempted to try..
regards Current: L322 TDV8 4.4
Post #473113 19th Mar 2018 1:57pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
If it's not your daily car I wouldn't bother to be honest.
If you do go ahead with it though, be interested to see and hear how you get on.
good luck Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #473114 19th Mar 2018 2:00pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
    Bio-ethanol is hygroscopic (it absorbs water) so using the vehicle only occasionally may well result is corrosion in the system
    Bio-ethanol has only 70% of the efficiency of petrol so more needs to be burnt to achieve the same performance
    Bio-ethanol does not have the lubricity of petrol and burns much hotter; this may cause damage to the fuel system/injectors and spark plugs
    Pure bio-ethanol is very difficult to start in cold weather. Commercially available fuel containing bio-ethanol has a ratio of 15:85 petrol:bio-ethanol for this reason
    Bio-ethanol is pure alcohol and may well attack plastic or rubber connectors in the fuel system
In short, don't do it
Post #473146 19th Mar 2018 8:21pm
