Home > Maintenance & Mods (L322) > Rear sub-frame corrosion |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Langley 4x4 in Kings Langley were highly recommended to me.
16th Jan 2018 7:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
You can find replacement rear subframes on eBay (usually from later models), just a fun job swapping them over! .
16th Jan 2018 9:11pm |
TheRealScotty Member Since: 26 Nov 2017 Location: Luton Posts: 3 |
I'm handy with the spanners so I did have a look on ebay but I expect the weight would be too much to handle on the drive. It could be an option if ok with the garage though.
16th Jan 2018 9:19pm |
Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11 |
i Just had exactly the same as this on a 2003 TD6, i bought a 2012 subframe that was like new, including all as new bushes for £240 delivered on a pallet.
28th Feb 2018 11:52am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1775 |
Shiiiiiiiiiit. That’s rusty
28th Feb 2018 6:49pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Might i respectfully suggest before you look at replacing the rear subframe, check the covered areas of the shell first... Remove the sill covers etc and check the tinwork has not killed the car before you start spending (maybe in vein) sir... |
1st Mar 2018 1:17am |
