Home > Maintenance & Mods (L322) > Rear sub-frame corrosion
TheRealScotty
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Hi. Long time lurker, first time poster so thanks for all your help so far.
I have a 2003 TD6 and it's just failed it's MOT. One of the "arms" of the rear subframe has completely rusted through. This is the photo I took when it was on the ramp so I know the garage isn't pulling a fast one
So, what sort of bill am I looking at and does anyone have any recommendations on where to go to get the work done? I'm based in the Luton area.
I have no intention of selling it, I figure that whatever I invest now will be less than buying a replacement.That and I love my FFRR
Post #464799 16th Jan 2018 7:43pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Langley 4x4 in Kings Langley were highly recommended to me.
My FFRR is in with them for the first time this week.
Will add my recommendation when it comes back Smile What do I put here then?
Post #464800 16th Jan 2018 7:49pm
You can find replacement rear subframes on eBay (usually from later models), just a fun job swapping them over! .
Post #464812 16th Jan 2018 9:11pm
TheRealScotty
I'm handy with the spanners so I did have a look on ebay but I expect the weight would be too much to handle on the drive. It could be an option if ok with the garage though.
Do you know if all versions of the L322 used the same sub frame or did it change over the years?
Post #464815 16th Jan 2018 9:19pm
Kinger
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
i Just had exactly the same as this on a 2003 TD6, i bought a 2012 subframe that was like new, including all as new bushes for £240 delivered on a pallet.
The labour at my local garage was £475, i had to have 1 tie bar, 2 new brake pipes and 2 new height sensors
All in it came out around £840 ish....
Mike
Post #470371 28th Feb 2018 11:52am
Mikey
Shiiiiiiiiiit. That’s rusty Shocked
Doesn’t look much fun to swap over either Confused
Post #470418 28th Feb 2018 6:49pm
Might i respectfully suggest before you look at replacing the rear subframe, check the covered areas of the shell first... Remove the sill covers etc and check the tinwork has not killed the car before you start spending (maybe in vein) sir... Thumbs Up
Post #470469 1st Mar 2018 1:17am
