Home > Technical (L322) > Part Numbers Request Please |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2498 |
According to 2012 Microcat for 2002 ZF 5-speed for M62 B44 4.4 Petrol V8
14th Jan 2018 5:40am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Find part numbers here as you will need o rings from memory and I changed my thermostat and holder and banjo bolts when we rebuilt my transmission so everything was new.
14th Jan 2018 8:15am |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 929 |
Thank you |
14th Jan 2018 9:57pm |
Will I need to replace ATF fluid? And do I need more than 1 O ring? Cheers |
14th Jan 2018 11:19pm |
I can't remember exactly but if you follow the procedure through in Rave, - download from the wiki it will tell you what to remove / replace . http://www.fullfatrr.com/wiki/Main_Page
15th Jan 2018 1:16am |
