![]() | Home > General (L405) > Engine issues 3.0 |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
I've had four tdv6's and all without a hiccup 2016 SDV8 Autobiography
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
Latest summary -
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1037 ![]() ![]() ![]() |
Have the same engine in my F Pace which has been perfect so far..... |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
In one of the earlier threads on this topic the OP reported that he was told that the problem with the 3 litre engine started with the last of the L322s and continued to 2015 and that the VIN range for the issue was known. This does seem likely as once the problem emerges it would be logical for JLR to fix the problem even if it took a while to do so.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
Well that's a load of |
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 679 ![]() ![]() ![]() |
Was that in a L405 ? |
What was the build date? Was it after mid 2015? |
The OP may have been referring to the L320 |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
The 13 plate 405 onwards I was referring 👍 _____________________________________________________
Scotty,
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
Just on the point about replies from dealers when asked about 3.0 TDV6 problems, when I asked at Lloyd Land Rover in Kelso I was told they had replaced several 3.0 engines. That may not all have been in 405s. It seemed to be a well known issue there. Some other dealers may be less candid.
If MY16 counts as 'after mid 2015' then there's an example on this thread |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Just to add to this thread , i was with a customer today who has a 2016 discovery and had his engine replaced 4 weeks ago. He was told crankshaft bearing. The workshop foreman advised he change it before the warranty runs out in case it happens again !!! I'm not sure if it's exactly the same engine as an L405 but thought i would post anyway. 2015 4.4 AB
