Home > Technical (L322) > td6 non starting when hot ( new pump fitted )
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
yes ive searched but I couldn't find anything conclusive past the leccy fuel pump causing hot no starts , it had a new leccy pump 3 weeks ago , and that primes up when you go to start it but it just turns over rapidly , I was at a merc garage this morning when he failed to start so I fired some PTFE spray up the EGR pipe and away it went almost immediately , put fuel in on the way back and again had to use spray to get him going again , no dash warnings at all , it runs and goes as it should , starts cold without a problem though I will see wether that's the case after work later
Post #464283 12th Jan 2018 1:20pm
miggit
Mine was a pig to start hot, when the injectors got blocked up / failed (2)... strangely it was quite happy starting cold Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #464316 12th Jan 2018 7:14pm
Paul thornton
Time to do a leak off test or plug in an IID tool I think.
Post #464318 12th Jan 2018 7:19pm
bembo449
I reckon your right pal , see if its starts when I get home from work , just more info on what its doing , then spill test it or off to my mates for a plug in IId stylee lol
Post #464323 12th Jan 2018 7:55pm
bembo449
Just plugged solus in and got P09F6 fuel rail cranking pressure fault , will spill test in an hour or so
Post #464374 13th Jan 2018 9:27am
Paul thornton
Sounds like you've got an injector fault then as if 1 or more leak off too much then there's not enough pressure supplied to the others being common rail.
Injector harness could also be at fault.
Post #464375 13th Jan 2018 9:32am
miggit
Err, you do know that there are 3 fuel pumps on an L322.... there's one in the tank, one outside by the sill and then there is the high pressure pump that's driven off the front of the engine... any of those playing up and it'll be a pig.. I'm assuming that you've done the outside pump? Yesterday I couldn't spell Engineer... Today I are one!
Post #464376 13th Jan 2018 9:33am
bembo449
Yes miggit , i know about the 3 pumps pal , leccy one is new , spill test with just ignition on shows no6 inj is leaking badly
Post #464388 13th Jan 2018 10:55am
Paul thornton
Crikey, it must be well knackered if it's leaking with just the ignition on as you've only got low pressure at that point.
What's it like when it's running?
I'd do a resistance test on the loom next and if that's ok replace the injector.
I highly recommend that place I got my reconditioned injector from.
Post #464396 13th Jan 2018 11:41am
bembo449
must be Paul but it runs sweet as a nut and always has since ive owned it , I use a place called CCS in a town not too far away , they will refurb it there and then so I can be mobile again within a couple of hours , looking at the other injectors , 3 have been marked up so its clearly had some work in this area before now , its just clicked over 132k
Post #464406 13th Jan 2018 1:36pm
miggit
Whistle I had the same thing on mine, when I took them out, a couple had been engraved, I didn't take a chance got the lot cleaned and tested.. 2 were dud and needed refurbing... after that it ran better that it ever had Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #464416 13th Jan 2018 3:05pm
bembo449
I will get the one done at a minimum pal , the others were all spilling pretty even , be nice to have faster starts thow Very Happy
Post #464446 13th Jan 2018 6:42pm
bembo449
6th injector , out and refurbed , starts like a good un Thumbs Up , also cleaned the blocked MAP sensor while I had the inlet off , need a good run really but only pottered to work today
Post #465042 18th Jan 2018 9:53pm
