Home > Technical (L322) > td6 non starting when hot ( new pump fitted ) |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Mine was a pig to start hot, when the injectors got blocked up / failed (2)... strangely it was quite happy starting cold Yesterday I couldn't spell Engineer... Today I are one!
12th Jan 2018 7:14pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Time to do a leak off test or plug in an IID tool I think. |
12th Jan 2018 7:19pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
I reckon your right pal , see if its starts when I get home from work , just more info on what its doing , then spill test it or off to my mates for a plug in IId stylee lol |
12th Jan 2018 7:55pm |
Just plugged solus in and got P09F6 fuel rail cranking pressure fault , will spill test in an hour or so |
13th Jan 2018 9:27am |
Sounds like you've got an injector fault then as if 1 or more leak off too much then there's not enough pressure supplied to the others being common rail.
13th Jan 2018 9:32am |
Err, you do know that there are 3 fuel pumps on an L322.... there's one in the tank, one outside by the sill and then there is the high pressure pump that's driven off the front of the engine... any of those playing up and it'll be a pig.. I'm assuming that you've done the outside pump? Yesterday I couldn't spell Engineer... Today I are one!
13th Jan 2018 9:33am |
Yes miggit , i know about the 3 pumps pal , leccy one is new , spill test with just ignition on shows no6 inj is leaking badly |
13th Jan 2018 10:55am |
Crikey, it must be well knackered if it's leaking with just the ignition on as you've only got low pressure at that point.
13th Jan 2018 11:41am |
must be Paul but it runs sweet as a nut and always has since ive owned it , I use a place called CCS in a town not too far away , they will refurb it there and then so I can be mobile again within a couple of hours , looking at the other injectors , 3 have been marked up so its clearly had some work in this area before now , its just clicked over 132k |
13th Jan 2018 1:36pm |
I had the same thing on mine, when I took them out, a couple had been engraved, I didn't take a chance got the lot cleaned and tested.. 2 were dud and needed refurbing... after that it ran better that it ever had Yesterday I couldn't spell Engineer... Today I are one!
13th Jan 2018 3:05pm |
I will get the one done at a minimum pal , the others were all spilling pretty even , be nice to have faster starts thow |
13th Jan 2018 6:42pm |
6th injector , out and refurbed , starts like a good un , also cleaned the blocked MAP sensor while I had the inlet off , need a good run really but only pottered to work today |
18th Jan 2018 9:53pm |
