Home > Technical (L322) > 2012 4.4 TDV8 Engine Bay
Popeye
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I have been trying to find a diagram on the layout of the engine bay as I would like to find out what the air box(?) is on the right hand side of the engine. The left is air intake. At first I thought it may be an air intake for each bank???
Please put me out of my misery???
Post #464295 12th Jan 2018 4:02pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
You are correct , two air filters 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #464296 12th Jan 2018 4:18pm
Popeye
Many thanks.... Bought some EGR cleaner that I sprayed into the intake pipe. Will have to get another one to do the other side now. Damn it!!!
Post #464297 12th Jan 2018 4:23pm
K8DJK
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
I understood one was for the primary Turbo and one for the secondary?
Dave
Post #464298 12th Jan 2018 4:31pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
The rest of BB's picture shows the rear and the numbered parts confirm the RH intake is for the 'fixed vane turbo'. The LH cleaner does the 'variable vane turbo'.
Which is the secondary one of those?
 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #464307 12th Jan 2018 6:00pm
K8DJK
Again my understanding, but the Primary is the variable vane turbo and the Secondary is the fixed vane turbo
Dave
Post #464310 12th Jan 2018 6:49pm
SinbadRose
Is the EGR valve cleaner spray any good? Seen the vids etc and what they show looks like it does the job.
Post #464315 12th Jan 2018 7:10pm
GraemeS
The primary is on the RHS. The secondary filter will be much cleaner than the primary due to lower usage.
Post #464324 12th Jan 2018 7:55pm
dolph34
I changed mine recently and the right ( drivers side) was quite dirty and the left was like new, im obviously not driving hard enough !!!!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #464328 12th Jan 2018 8:16pm
GraemeS
For reduced dust intake I've considered fitting a slightly modified D3/4 snorkel to the right side only as the secondary turbo on mine is rarely used.
Post #464340 12th Jan 2018 9:31pm
UK drivers side is the main turbo the other/passenger side is the secondary turbo... Thumbs Up
Post #464347 12th Jan 2018 10:05pm
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Anybody know if EGR spray cleaner is any good? If it is, is there a preferred make to go for? Thanks.
Post #464363 13th Jan 2018 2:05am
GraemeS
There is only 1 EGR valve on this engine so spray into the primary intake only.
Post #464364 13th Jan 2018 3:19am
Popeye
I used the Wynns EGR Cleaner Spray. Noticed a little difference, not sure if it has fixed the EGR Valve yet as not had a chance to plug in the IID Tool yet. Will let you know.
Post #464640 15th Jan 2018 12:07pm
kgeddes
Thanks Popeye, interesting to see if it makes any difference.
Post #464758 16th Jan 2018 1:08pm
