Home > Maintenance & Mods (L322) > HVAC ATC module
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
HVAC ATC module
My Rangie is suffering air conditioning problems and my local Indie has advised I need a new ATC module.
It looks fairly straight forward to change it, but is it plug and play?
If not, how are they programmed? Can the IID tool program these?
(Hopefully a photo is attached)
 2007 3.6 TDV8
Post #464244 11th Jan 2018 11:56pm
cheezels
Bump Very Happy 2007 3.6 TDV8
Post #464270 12th Jan 2018 12:25pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
When I had an ac fault I bought a spare one of these to test if that was my problem (it wasnt so didn't install it in the end) and it simply plugged in, no programming or coding needed as far as I am aware.
Post #464336 12th Jan 2018 9:02pm
kezbo1981
P.s. Make sure the replacement one you get is the same as the one in your car. Some differ, for example the one in your photo doesn't have the heated seat buttons.
Post #464338 12th Jan 2018 9:13pm
