Home > Technical (L322) > Probable belt failure - looking for procedure/advice |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2480 |
The squeaking is likely to have been caused by a failed tensioner or idler pulley bearing. |
9th Jan 2018 2:01am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Download rave from the Wiki http://www.fullfatrr.com/wiki/Main_Page
9th Jan 2018 8:28am |
Sennokian Member Since: 15 Sep 2017 Location: South East Posts: 4 |
The belts are off. Can’t tell at the moment if they’re damaged, but let’s face it...
10th Jan 2018 3:47pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
Very easy to do on the drive - just look at the wiki and make sure you have the right tools to take off the viscous fan.
10th Jan 2018 5:05pm |
remove Fan (don't need to remove the rad) - do need special spanner and holding tool ideally _ apparently has been done by passing the belt over the fan but all i can say to that is good luck
10th Jan 2018 11:28pm |
