Home > Technical (L322) > Probable belt failure - looking for procedure/advice
Sennokian
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Epsom Green
2003 V8 Vogue petrol
I recently lost power steering while driving, pulled over and noticed the coolant was boiling, and the battery light came on.
I haven’t been able to look yet, but am assuming it’s the belt. Either come off or just broken. I had heard some squeaking from the engine around Xmas but just been so busy. Not a squeal like a slipping belt but a continuous squeak.
Anyway I’m going to check it out tomorrow and wondered if anyone has a workshop manual covering this procedure or any advice on the complexity of fitting a new belt or what else to look for. I read somewhere about having to work around the air con but this may be just the diesel layout.
Any advice/tips welcome - in particular anything else worth maintaining while I am working in this area.
Post #463865 9th Jan 2018 2:56am
GraemeS
Australia
The squeaking is likely to have been caused by a failed tensioner or idler pulley bearing.
Post #463866 9th Jan 2018 3:01am
holidaychicken
Download rave from the Wiki http://www.fullfatrr.com/wiki/Main_Page
As above, you may need a tensioner and check your water pump bearings for play but the belts are prone to fail if not changed in a while
Post #463877 9th Jan 2018 9:28am
Sennokian
The belts are off. Can’t tell at the moment if they’re damaged, but let’s face it...
Is this something I’m likely to be able to do on a drive without any way to raise the car? It looks pretty busy in there.
Post #464012 10th Jan 2018 4:47pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Very easy to do on the drive - just look at the wiki and make sure you have the right tools to take off the viscous fan.
Removing the fan makes it a much simpler job...ask most of us on here how we know Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #464023 10th Jan 2018 6:05pm
holidaychicken
remove Fan (don't need to remove the rad) - do need special spanner and holding tool ideally _ apparently has been done by passing the belt over the fan but all i can say to that is good luck Smile
i had my undertray off when i did mine but cant remember if you need to
http://www.fullfatrr.com/forum/topic16155.html
Belt (this is waterpump wiki)
http://www.fullfatrr.com/forum/topic16423.html
Post #464100 11th Jan 2018 12:28am
