Home > Technical (L322) > Steering Wheel Alighnment |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
cant see that jacking up the rear would affect the front..baffling it is.. ... - .- -.
9th Jan 2018 8:30pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Strange indeed. I think you need to get it on a ramp and check bushes and joints with a pry bar. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
10th Jan 2018 2:16am |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 |
Grofus. Indeed that would have been my first thought also. However all the front suspension arms, bushes, track rod and steering rack arms have been replaced within the last three months. Not to.mention the front wheel bearings as well. |
10th Jan 2018 8:43am |
Even more baffling. How far off was it. Could it be camber of the road?
10th Jan 2018 1:55pm |
Before the incident the steering wheel has always been about 10mm off centre clockwise. Now it is 10mm off centre but anti clockwise!! Maybe it needs a good offroad drive too sort the suspension out. Will look to see the best local place to have a 4 wheel alignment check done. |
10th Jan 2018 6:53pm |
I meant to post an update earlier. Problem found to be a failure of the nearside rear top knuckle bush. Strange these were replaced not many months ago and it was a Lemforder one. Inner bush tubing was moving laterally on the bolt. All sorted. Thanks to those that replied. |
12th Mar 2018 5:40pm |
