![]() | Home > In Car Electronics (L405) > Volume decreases in reverse. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
probably so you can hear the reverse bleeper better.... ... - .- -.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
Ignore the reverse beeper, I do, but you will hear the crunch better when the car stops and you have backed into a wall |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1543 ![]() ![]() |
It seems that many drivers manually turn the volume down when reversing. Perhaps it's to reduce distraction when reversing.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
I’m sure the wife’s Ewok does this.
basil Member Since: 09 Dec 2014 Location: UK Posts: 88 ![]() ![]() |
Now if only my wife's volume would decrease when I put my RR into reverse, life would be so much better... |
S33MAF Member Since: 04 Feb 2014 Location: WC Posts: 216 ![]() ![]() |
Ok so decided it’s not for sensors as it's intermittent, as in the volume fluctuates as you reverse.
Look in your ICE settings. In our Subaru Forester, there is a setting to reduce the audio volume when reverse is selected. Maybe later LR do the same. Ron B. VK2OTC
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
They all do that now. Even the wife's VW does it 2020 Porsche Panamera Turbo Hybrid (V FAST)
dfulgo Member Since: 16 May 2015 Location: Milan Posts: 70 ![]() ![]() |
... not only in reverse, also when front parking sensors are engaged, it should be because of making the beeps more audible so, if you manually decrease the volume, while beeping, to zero, then you only get the general audio decrease, ...more or less like with the navigation directions...
