![]() | Home > Range Rover P38 > P38 off roading |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
I believe that Green-oval-nut was selling such a beast..... might still be available! Yesterday I couldn't spell Engineer... Today I are one!
http://www.fullfatrr.com/forum/topic44638.html?highlight=p38 Yesterday I couldn't spell Engineer... Today I are one!
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Have a look on AULRO.com, there is a very long thread about lifting P38`s. It involves fitting blocks under air springs and extending the hight sensor arms. All bits can be purchased I believe. I have done some serious offroad trips in P38`s here in oz in a stock standard 4.6Thor, they are extremely capable in the rough stuff. Only mods were running 265 70 16 tyres, beyond that size, you will get big rubbing issues, and uprated shocks. 2007 TDV8 VSE
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
It’s got air suspension. So why lift it? They’re very capable in stock form. |
Just use your 322 |
I sort of agree and when I had my P38`s I found no reason to modify apart from a rear locker and 265 70 16 tyres. Lifting the suspension gives room for larger rubber= more clearance under the diffs . Also lifting gives greater wading depth. Cam Tech Craig, every Range Rover I have ever owned has been used off road regularly without concern. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 ![]() ![]() ![]() |
Would you not consider a Doscovery 2.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
I use the 322 off road and keep the P38 super tidy - well when I am not also taking it off road |
And there was my 322 in the background of your 1st pic J |
PeterY Member Since: 01 Feb 2015 Location: Oxfordshire Posts: 21 ![]() ![]() ![]() |
I’m too precious about my 322 to risk a scratch off roading too much I still get it muddy every now and then though!
Peter, Here is my TD5
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1415 ![]() ![]() |
Craig !
They’re all for sale sir |
