Are you losing any water?
There is a kit a garage can place on the expansion tank to see if its contaminated with gases from cylinder head gasket failure.
I would be getting the injectors tested with a leak off test first.
How is it when the engine gets warm (maybe the block had warmed through the second time you started?). It could be a number of glowplugs failed as that would contribute to lumpy running from a cold start. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
