![]() | Home > Maintenance & Mods (L322) > Grooved Drilled Discs? |
Andy-B Member Since: 23 Mar 2017 Location: Todmorden Posts: 21 ![]() ![]() ![]() |
Noisy as hell! Stick with OEM plain discs.
2nd Rower Member Since: 24 Sep 2009 Location: Upside Down Posts: 62 ![]() ![]() ![]() |
Thanks |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
As already stated, they do make a difference, but there is noise when braking heavily, worth it you you get regular brake fade / or you can smell them |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1543 ![]() ![]() |
My rears are drilled/slotted and I don't find them to be noisy. Ron B. VK2OTC
I had them fitted to the front, and you could hear them when you stood on the pedal.... remembering that the fronts do 70% of the braking, it would mean that the rears are 70% quieter |
MONT322 Member Since: 22 Jan 2017 Location: Surrey Posts: 33 ![]() ![]() ![]() |
My 322 came with drilled front and back and I've found them to be noisey with vibration coming through the brake pedal inside the car under heavy braking and squealing like mad outside the car when coming to a stop no matter what speed!
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Well i don't know which grooved and drilled discs Craig put on mine when he had it and i bet they weren't cheap but i wouldn't go back to normals now ever after these, quiet as standard but more than double the breaking than a pals 2011 and no noise difference |
Thanks for all the replies...
