![]() | Home > In Car Electronics (L322) > drivers electric seat after battery change |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Hi folks
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
disconnect the battery ,wait a bit and reconnect remembering to do the steering left to right business....it could be yours is just having a paddy.. ... - .- -.
actually - I forgot to the do the left to right bit anyway - Just changed the battery as well |
kudus to you if you can get up to 10 minutes, my best time is about 2.... |
lol - its Christmas so have to try really hard first.. |
A little update but still not fixed.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
or you need to do the full battery reboot thing. I think you disconnect battery then wait for a bit then touch the (unconnected) pos and neg leads together.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
is passenger seat workin?
hmm - thanks all
Just popped out to re check with IID - All seems to be set correctly - here is the error I got
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
Go back in with your IID and you have a “reset factory CCF” setting at the bottom of the front page...
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
I’d be more than a little concerned that the voltage was showing as 11.7v |
Alan, thats absolutely normal 11.7v whilst using the IID sir |
