Home > Maintenance & Mods (L322) > SRS Airbag Light
mercs600
England 2002 Range Rover Vogue Td6 Java Black
SRS Airbag Light
Had to take the missus to work the other day due to the weather , so , as car was frozen started it up and ran it to demist and clear the frozen screen etc - all OK and turned off. Went back an hour later and now on start-up and run I have the dreaded SRS Airbag light lit ! No movement of seats etc and all connectors OK , Yellow cable connector on battery also good. New battery 2 months ago and all fine. Unable to purchase a IID tool until next month so was wondering if there is anyone local to me with the ability to read and clear the fault please ? Located in Scarborough - thanks in advance. Wink
Post #462723 30th Dec 2017 2:34pm
Crispian22
First thing I'd do is give the battery a good charge,wether newish or not it could be run down.
Post #462741 30th Dec 2017 5:16pm
mercs600
Thanks for that. Battery is fine and spins and starts engine quickly , as well as have 2 x good trips. Dont believe the battery is the issue though. I will hook up the charger and see what I get though to be on the safe side. Wink I believe I am correct in stating that as a fault is currently registered it will be stored so will require software to reset and clear it.
Post #462744 30th Dec 2017 5:34pm
my old td6 had a airbag light come and it was the occupancy sensor in the seat base that was faulty. ... - .- -.
Post #462745 30th Dec 2017 6:00pm
mercs600
Cheers Stan - Thats my line of thinking seeing it was all OK until the missus sat in the passenger seat.
Post #462758 30th Dec 2017 8:46pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Same with mine. The light occasionally comes on, but only when I have a passenger and they are moving about. It is the sensor under the seat. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #462879 1st Jan 2018 12:44pm
Carl 40BMI RRSC
England 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Hiya, did you manage to get it sorted cos I am having the same issue. I’ve heard you can bypass it but I can’t even find the module? I have a 2005/6 Vogue Sc. Any help would be appreciated.
Post #506618 27th Feb 2019 8:44pm
