![]() | Home > Maintenance & Mods (L322) > SRS Airbag Light |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 141 ![]() ![]() ![]() |
First thing I'd do is give the battery a good charge,wether newish or not it could be run down. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Thanks for that. Battery is fine and spins and starts engine quickly , as well as have 2 x good trips. Dont believe the battery is the issue though. I will hook up the charger and see what I get though to be on the safe side. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
my old td6 had a airbag light come and it was the occupancy sensor in the seat base that was faulty. ... - .- -.
Cheers Stan - Thats my line of thinking seeing it was all OK until the missus sat in the passenger seat. |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Same with mine. The light occasionally comes on, but only when I have a passenger and they are moving about. It is the sensor under the seat. No longer FF owner but still interested. Present car Jaguar XE
Carl 40BMI RRSC Member Since: 02 Jan 2019 Location: Coventry Posts: 8 ![]() ![]() ![]() |
Hiya, did you manage to get it sorted cos I am having the same issue. I’ve heard you can bypass it but I can’t even find the module? I have a 2005/6 Vogue Sc. Any help would be appreciated. |
