![]() | Home > Maintenance & Mods (L322) > Labour cost to replace front and rear discs and pads |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 ![]() ![]() ![]() |
Euro car parts with one of there discounts. Might be 50% off at the moment.
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
+1 on euro car parts - screwfix has discounts on tools right now as well for geting your bottle jack axel stands and caliper winder |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 731 ![]() ![]() ![]() |
Cheers guys, just priced it all up with ECP with their 'XMAS17' discount code and coming in at £245 for the lot
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
The fluid should be changed regularly, but if you do decide to change it, you need to be aware of the risk of snapping bleed nipples etc as well as the order of bleeding, especially where ABS is concerned.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Don't forget the disc fittings kits and you will almost certainly need new brake wear sensors. |
Thanks all guys
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Front and rear daily driver pads are about $50 USD. I don't see a reason to change the wear sensor unless you wore into it. About $30 for both. I believe they ship internationally or you could use your savings to pay for a round trip ticket from New York to London and I will hand deliver them. |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
doclees is spot on. the wear sensor wont need changing unless its worn into. |
Thanks guys
True, but bear in mind that the sensor is held in by a tiny spring and if you're not careful when removing it, you can break the sensor since they seem to get brittle over time. Mike |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
It is a pretty easy job with the right tools. Where the sensor fits into the calliper is often a bit rusted over. I would spray it with some penetrating oil and leave it for a while before attempting to remove it, less chance of snapping it then.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
The previous post sums up why this forum is so excellent.
Oh I missed you are doing the disks too. About another $120 for all 4. |
Dot 4 is the fluid you need. |
