Home > Technical (L322) > No blowers to windscreen problem. |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
I think the servo flaps to the windscreen have stuck.
27th Dec 2017 9:08pm |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 301 |
So it seems to be the flaps jammed indeed. I just had another play and it seems footwell and screen are not working. Whatever you select you get front vents only and nothing changes.
27th Dec 2017 9:20pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Stuart, try presing MAX A/C. Unjamed My. |
28th Dec 2017 8:26am |
I have, and pretty every much other possibility. Max AC makes a lot of noise but no air where I want it. |
28th Dec 2017 10:24am |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
Mine is the same except I do have 1/2 a heated windscreen, unfortunately it's the wrong half , only just got the car so not investigated it yet.
28th Dec 2017 10:29am |
All part of the joys of RR ownership I guess.
28th Dec 2017 10:34am |
I think I've found my problem , I can hear the fan running , moving between the 3 buttons doesn't alter the airflow in any direction , pressing the max button closes the vent from outside but all that does is make more noise
29th Dec 2017 12:25pm |
Switching between max then the 3 direction buttons a few times appears to have cleared mine , seems to be working ok now , I'd give that another go before paying somebody to strip the dash , I've read 2 days labour for that on t'internet |
31st Dec 2017 5:35pm |
Electric screen decided to work yesterday, but conked out again today. Sounds like a fuzzed up connector block to me (the Sport is known for this on the rear window). I'm assuming it will be behind the pillar trim? |
1st Jan 2018 5:35pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
I suspected I had the same problem and found access was behind the black cussioned panel next to the switches for suspension etc , you can clearly see the flap move when depressing each position , I unhooked it just to make sure it wasn't jamming up |
1st Jan 2018 5:56pm |
After an overnight freeze I again found I had no demisting air to the windscreen. I kept the engine running whilst pressing every variation of buttons imaginable (which reminded me of playing Whack-A-Mole).
8th Jan 2018 8:19pm |
Preliminary investigations by Land Ranger suggest the dash has been out in the past, probably to replace the heater motor they are apparently renowned for. Someone made a hash of putting it back together hence the flaps are not working as they should and the heated front screen works when it feels like it.
15th Jan 2018 7:15pm |
