Home > Maintenance & Mods (L322) > Rear doors locking fault and steering. FIXED!!!
Ken_Curtis
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Hello all
Have been experiencing intermittent problems with both rear doors not unlocking and and sometimes at the same time the steering being mega heavy. If I cycle the ignition, I can "trick" the steering into working.
I am thinking now that both faults are linked. I took the car in to my local garage and got the faults read from the car and was recommended the servotronic valve be replaced on the steering rack, but this has made no difference, the wiring was OK.
Reading further on the tinterweb, it looks like the Body Computer or BCM is at fault. The cost with coding will be around £300, but I am reluctant to just throw another load of money at this problem and still have these issues.
We love the car, its only got 87,000 mile on it, but these faults are driving me MAD! Please help!!
BTW, the car is a Td6 made in October 2004.
Merry Christmas everybody. Ken
Post #462052 24th Dec 2017 2:17pm
Dolphinboy
Deffo the bcu. U could try a second hand one on eBay for £100ish. Make sure it’s the part number impending 22.
How much have you been quoted for the re-coding?
Post #462064 24th Dec 2017 3:57pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Yep, +1 for BCM. Second hand is more trouble than it's worth. I think the module stores data like mileage etc. So it's a pain to change it to another car. Then of course you could be doing it again in 6 months. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #462069 24th Dec 2017 4:27pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I'd pull a rear door lock and test power it. I did with a 9v battery. PO bought the beast with about 100k miles and bother rears and drivers door locks were dead. If you can get 10 or more cycles without a fault then I would assume the locks are good. Also if you love the truck think about investing in an iidtool. Worth every penny.
Post #462071 24th Dec 2017 4:35pm
bebechoon
France
I agree with Grofus and Dolphinboy - it sounds like a typical BCM problem
Been there, done that Thumbs Up
See http://www.fullfatrr.com/forum/topic40009.html
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #462074 24th Dec 2017 4:38pm
Ken_Curtis
Thanks for the reply.
To be honest I don't entirely trust the garage that quoted me on replacing the BCM, they said the coding will normally cost £45.00, but as I have spent with them already they will keep the job to £300. They said the car will not do anything without a coded BCM in place. Hmmm.
I have found it under the front passenger seat. I tried the car without the BCM connected and it starts and drives, but no locking, windows, steering and no wipers. I then plugged it back in and everything works everytime!! By unplugging it for the 30 mins must have reset it.
I am not normally this lucky, time will tell.
Post #462077 24th Dec 2017 4:47pm
Ken_Curtis
Hi All
Many many thanksto you all for your replies.
I have just read the thread by Bebechoon and the how-to.
If the reset proves no good, how much should I expect to pay for a new BCM?
Ken
Post #462081 24th Dec 2017 4:59pm
Grofus
If £300 includes the module, then it's very reasonable. Hopefully you won't need it for a while yet.
You don't say if the garage was a LR specialist. If not, then find a good one as these cars have more quirks than most.
Specialist knowledge saves many headaches. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #462089 24th Dec 2017 5:44pm
bebechoon
France
I bought my new BCM from Ducky Dan - site sponsor "duckworthparts". He was the cheapest I found.
I paid £213 including delivery to France, but that was in August 2016.
Contact Dan for a quote!
Previous:
Disco II
Post #462091 24th Dec 2017 6:07pm
Ken_Curtis
Many thanks for the replies.
I have just been out in the old bus and all is good, I am keeping everything crossed!
The garage is an "All makes specialist", a friend of a friend. It was a 70 mile round trip and to no avail.
If it faults again I will get a quote from Ducky. I don't really fancy spending £100 on a used BCM as the car is a "keeper". In the 10 years this has been in the family its been faultless apart from a suspension level sensor failing.
What is a fair price for coding a new BCM to the car?
Ken
Post #462097 24th Dec 2017 6:51pm
Grofus
Use a good Indie and it's about an hour's labour. £40- £60 should cover it. If you have a gap iid BT I think you can do it yourself. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #462177 25th Dec 2017 6:53pm
Ken_Curtis
Well, I thought the reset had fixed it but the gremlins have returned with a vengeance today.
It took 7 or 6 goes with the ignition to get power steering up and running, I didn't try the rear doors. The other thing I noticed was the parking sensors not picking up when parking in front of a wall. The wife drives this a lot more than me so I will ask her later.
Yesterday it was faultless, but its quite a bit colder today so its probably related to temperature.
Will price up a BCM tomorrow.....
Post #462213 26th Dec 2017 12:36pm
Ken_Curtis
Hi All
It looks like its turned into a permanent fault, I tried my reset routine over night and no luck.
A new BCM is £235 including delivery, so the cost of sorting out the car will still be under £300, not the end of the world.
However, my wife has found a repair service for these kind of faults. I have called them and left a message this morning, it might be they are not working until the holidays are over. They are almost on the way to Huddersfield where we are visiting on Friday. The only thing is driving it without power steering for 50 miles and will it cause damage?
Post #462282 27th Dec 2017 8:51am
Ken_Curtis
I got called back and the car is booked in this Friday morning to get it plugged in to a diagnostic machine to verify 100% its the BCM causing the issue and rule out wiring.
Melvin has a BCM spare with a basic program in so we can continue our journey while he repairs our BCM, which should be ready on our return journey. Its a fixed cost repair of £70, if it cannot repaired we dont pay. I quizzed him on the chance that our BCM cannot be repaired, he replied that he can supply another BCM from his stock with the memory transferred from our old unit, this will cost £50 more though.
He sounds confident on getting this sorted as he repairs the same BCM in the BMW X5's. If all goes to plan the cost will be £70, which is better than over £280 for a new one!!
Post #462295 27th Dec 2017 11:53am
doclees
Sounds like a proper plan. I'd assume these suffer bad solder joints from vibration over time. Unless it got drowned at some point.
Post #462318 27th Dec 2017 2:25pm
