![]() | Home > Technical (L322) > Brake lights on ignition off |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
brake switch or faulty/wet lcm behind the bonnet release lever panel.. ... - .- -.
andyfid Member Since: 10 Apr 2016 Location: barnsley Posts: 104 ![]() ![]() ![]() |
I will take a look at those tomorrow if the weather is dry cheers Stan 👍🏻 |
Rockyd31 Member Since: 17 Dec 2016 Location: Chesterfield Posts: 36 ![]() ![]() ![]() |
+1 agree with Stan. I had similar issue where 3 led's in each light remained on, traced it back to condensation around the LCM and harness. Quick dry and clean out with contact cleaner fixed it |
Cheers for that going to check the lcm this weekend I checked the brake switch and that's fine just hope it is damp and it's not |
looks like i could have a faulty lcm checked today for damp and its dry and no signs of watermarks tried unplugging and cleaning the contacts with electrical cleaner replugged and fitted lowand behold the lights slowly come back on ![]() |
well the bloody thing is still on i have tried pulling all fuses checking for water and still the leds are on i am now getting ready for a gallon of petrol and a match had it to a auto electrician and he couldnt find a thing he was as much good as a chocolate fire gaurd can anyone recommend some one local to barnsley |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
I had this problem last night, brake lights came on as soon as car went to sleep (red light by "P" goes off). Disconnected battery to investigate in the morning.
so what do you reckon, sticky brake switch? ... - .- -.
Not really any moving parts on the brake "switch" it is more like an ABS sensor but one that needs to be in contact with the metal of the brake pedal [EDIT](or like an ABS sensor there should be a small gap, but enough for the sensor to work)[/EDIT]. Whether the brake pedal had got stuck "off" it I don't know. No bright red glow outside so whatever I did has done something. No doubt need to drive it a bit. .
Sunday morning, 0745, awoken by the alarm going off. Ran down stairs, grab the keys, but alarm finished by then. Immediately alarm started off again so aimed at the car and pressed unlock. Nothing. Went outside pressed the unlock, nothing. Then could see that aside from alarm going off - hazards flashing, wipers were at 90 degrees, headlamp wipers also, stop lights on. Put key in drivers door and unlocked, key wouldn't turn in ignition. Alarm still going off!! Popped the bonnet. Ran back inside to the garage, grabbed 10 mm spanner, back outside, released earth terminal on battery. Silence.
not what you need this time of year.... |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
That doesn't sound too healthy!
Some background reading from the forum:
Had a look:
