Home > Maintenance & Mods (L322) > ''water in fuel''
Laughing
i'm actually using all those words at the moment Shocked .......thanks for the tip but i'll use the craig-meisters suggestion and let the LR minions sort it.. ... - .- -.
Post #461993 23rd Dec 2017 10:39pm
Thumbs Up Thumbs Up Thumbs Up Whistle
Post #461999 23rd Dec 2017 10:50pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
That's the best solution Stan, but I have bought a few pair of these gripp gloves for people with arthrosis or arthritis and they are very handy with these kind of repairs.
Post #462092 24th Dec 2017 6:12pm
theres no room to get your hand in there to grip and turn Robert ... ... - .- -.
Post #462120 24th Dec 2017 9:33pm
nino_nino
Happy Christmas to all,
Taking out air box:
Time 20 min.
skill 1 to 10 = 3
tools: screwdriver.
unplug MAF sensor and remove wire from the box.
loosen two jubilee clips on the air pipe and remove, pull air box to the side and after it is clear of the rubber grommets pull up.
with box out it is easy to axes the nob on the full filter housing.
pictures tell the story :
Post #462149 25th Dec 2017 11:26am
merry xmas nino....
that looks like a plan..i've just looked at mine and can relate to your pics and your solution gives a lot more 'undoing' space... Thumbs Up ... - .- -.
Post #462151 25th Dec 2017 11:36am
Baltic Blue
Nino,
I hope you are going to clean that air box whilst it is out. Rolling with laughter Rolling with laughter
Cheers
Mike 🌲🌲🎅 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #462152 25th Dec 2017 12:24pm
nino_nino
BB, now that is very spooky, just how did you know, I did indeed Rolling with laughter
Post #462155 25th Dec 2017 12:46pm
dirtymonkey38
What size tubing fits on the drain? 2011 RR Autobiography 4.4 TDV8
Post #526170 26th Aug 2019 5:38pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
It doesn't take a whole lot of time to disconnect the hoses and lift up the entire filter unit. Not much spillage either. 2007 L322 3.6 TDV8 Stornoway
Post #526203 27th Aug 2019 3:58am
rjff
dm38
A 5mm ID silicone tubing worked for me. Flexible and easy to wriggle on. The sensor connection is similar to the old spark plugs. Tape a stick to the other end of the tube and it goes down to the ground a treat. Place the outlet in glass jar standing in a tray, (guess why?). Cheers
Richard
Gap IIDBT
Post #526240 27th Aug 2019 1:43pm
