Home > Maintenance & Mods (L322) > ''water in fuel'' |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
i have been getting this dash message occasionally for the last week or so , and although the westie is getting a service next month which includes a new fuel filter i thought i'd have a go at draining the water off.
23rd Dec 2017 1:32pm |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 |
Have you got a strap wrench Stan? Access might be abit tight though. |
23rd Dec 2017 1:42pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Stan,
23rd Dec 2017 1:57pm |
steve & mike, you cant get anything like that onto it..the 'nut' is right underneath the filter and you can just about get your fingers onto it but theres no room to grip it properly..
23rd Dec 2017 2:05pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Sorry no advice but wanted to answer becuase you are always so helpful. Good luck 2015 4.4 AB
23rd Dec 2017 2:27pm |
Also Stan adding extra water to your tank will not improve
23rd Dec 2017 2:56pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
If the sensor is anywhere near as reliable as the version on the Discovery 2, the Land Rover official Service recommendation will be to pull the wiring connector off the sensor , tape it up & then no longer worry - lol.
its not a proper nut shape as such, more of a circle with notches..
23rd Dec 2017 3:15pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
23rd Dec 2017 3:51pm |
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 |
Nino! |
23rd Dec 2017 4:44pm |
Stan, is it the grooved "wheel" in between the sensor & filter in this pic.?
23rd Dec 2017 4:47pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Just leave it until the service pal... Much easier |
23rd Dec 2017 6:43pm |
23rd Dec 2017 8:40pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Stan, you should be able to pull the electrical connector off and wearing rubber gloves, be able to get enough purchase on the drain cock.
23rd Dec 2017 10:19pm |
