Home > Maintenance & Mods (L322) > ''water in fuel''
''water in fuel''
i have been getting this dash message occasionally for the last week or so , and although the westie is getting a service next month which includes a new fuel filter i thought i'd have a go at draining the water off.
now i do have a fairly strong grip but could i undo the plastic knurled nut, could i heck!...any tips on undoing this nut? ... - .- -.
Post #461908 23rd Dec 2017 1:32pm
SteveRRL322
Have you got a strap wrench Stan? Access might be abit tight though.
Post #461909 23rd Dec 2017 1:42pm
Baltic Blue
Stan,
Could you get access to use one of these?
If you think it will do the job, I am going to send for one because I have never drained mine.👍
Cheers
Post #461915 23rd Dec 2017 1:57pm
steve & mike, you cant get anything like that onto it..the 'nut' is right underneath the filter and you can just about get your fingers onto it but theres no room to grip it properly..
i did undo the fuel filter housing nuts but the fuel pipes themselves restrict movement of the loosened fuel filter so that didnt help.
the only way i can see is to undo the filter itself ,take it out and do the drain then but i'm not sure if this is possible.. ... - .- -.
Post #461916 23rd Dec 2017 2:05pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Sorry no advice but wanted to answer becuase you are always so helpful. Good luck Smile 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461920 23rd Dec 2017 2:27pm
SteveRRL322
Also Stan adding extra water to your tank will not improve
Your mpg 😂
Post #461927 23rd Dec 2017 2:56pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If the sensor is anywhere near as reliable as the version on the Discovery 2, the Land Rover official Service recommendation will be to pull the wiring connector off the sensor , tape it up & then no longer worry - lol.
On Disco 2s , many owners or dealers would attempt to drain off water & never find any. For later versions, LR removed the sensor on UK spec vehicles with no known issues.
I'm not sure on the L322, but is the fuel tank plastic ? If so, the only cause of water in diesel should be a dodgy supply. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #461928 23rd Dec 2017 2:56pm
GGDR
Would a tap spanner do it Stan?
Not sure if you've seen these but they can reach behind a sink to tighten a tap.
Like this:
Can you post a pic showing the access?
Greg Cheers, Greg
Post #461930 23rd Dec 2017 3:06pm
its not a proper nut shape as such, more of a circle with notches..
its defo tight access.. ... - .- -.
Post #461932 23rd Dec 2017 3:15pm
nino_nino
Stan, I had same problem, water in fuel message, and could not loosen the sensor - my remedy - remove air filter box and it will give you enough space to use small pipe wrench or pliers, or the alternative is this:
and after couple weeks try again Rolling with laughter (sorry could not resist) . Very Happy
ps
there was no water in the fuell. I sprayed some "CorrosionX" on the contacts and had no recurrence since.
Post #461936 23rd Dec 2017 3:51pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Rolling with laughter Nino!
Post #461942 23rd Dec 2017 4:44pm
Pawl
Stan, is it the grooved "wheel" in between the sensor & filter in this pic.?
Same as the blue item in the service manual pic.
I assume someone has massively overtightened it previously as it should only be hand tight.
Edit : (don't know how this bit got cut off)
Could you get a couple of elastic bands loosely round it to get extra grip ? Paul,
Post #461943 23rd Dec 2017 4:47pm
Just leave it until the service pal... Much easier Whistle Whistle Whistle
Post #461960 23rd Dec 2017 6:43pm
its the bit thats arrowed pawl....
@craig, wise words Wink
@nino, Ner Ner ... - .- -.
Post #461975 23rd Dec 2017 8:40pm
mpirie
Stan, you should be able to pull the electrical connector off and wearing rubber gloves, be able to get enough purchase on the drain cock.
Alternatively, try and wrap a bit of rubber hose around the nut to give a better grip.
Man, it''s Saturday night and after a few whisky's, I should not be answering forum questions with words like nuts, cock, rubber and grip!! Rolling with laughter Rolling with laughter Rolling with laughter
Mike
Post #461989 23rd Dec 2017 10:19pm
