![]() | Home > Technical (L322) > Front Suspension Knock |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
Our late 2006 3.6 TDV8 has the infamous front suspension knock from both sides - only occurring at low / manouvering speed while using significant steering lock.
GraemeS,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
I just added a note to my post noting that MCAT isn't error-free so perhaps LR018343 LR018345 is still current.
None of the forum posts about suspension knock mention anything about LR changing the compression arm bush design, so there's no clue which may be better than the other.
I purchased my April 2012 build with 18k kms on the clock and its front suspension rattled then, but is slowly getting worse . It gets a hard time with its oversize tyres and lots of rough tracks/roads and it wont be too long before I replace those bushes in the hope that the rattle abates. |
It's bad that you got the noises so early! I assume you decided to just accept it.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Is it a continous knock?
Umitbat,
Pawl,Yes it is!!
Mine rattles going forwards or reverse over bumps including car-park speed humps. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
A rattle is more likely to be the ARB control links👍🏻 Cheap and easy. There is nothing that can't be fixed with a hammer😜😜
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
my worst rattle was the driver side lower ball joint , knocked it tits off , the other was a rear arm bush on the same side but that was only at speed and while turning left |
Its been a while but mine's rattle was caused by a floppy right side lower ball joint, the same as Bembo449's.
