Home > Technical (L322) > Front Suspension Knock
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Our late 2006 3.6 TDV8 has the infamous front suspension knock from both sides - only occurring at low / manouvering speed while using significant steering lock.
I've tried checking for ball joint play & worn bushes & the only thing I can identify is that the upper control arm (the rear compression strut) rear bushes flex rather easily & the internal rubber section doesn't look quite the same shape as images of new bushes on the internet. The rubber doesn't look significantly degraded / split, but there are a few small cracks.
It's very easy to rotate the arm so that it hits the nearest bit of the subframe - which I assume is what's happening when I put on the steering lock.
I'm having problems working out which replacement arm assemblies to buy.
The online Microcat that the Wiki links to indicates part nos LR018343 / 344 are correct & supercede the earlier parts RBJ000120 / 130 which had a different bush ( probably to reduce the knock problem ??).
However, many of the suppliers appear to be still selling the older RBJ000120 / 130 part nos - as if they are interchangeable & often at cheaper prices than other suppliers selling the LR018343 / 344 parts.
Has anyone seen the older & newer parts side by side & understands the differences?
Judging by the huge discussions about the problems of eliminating the knock - seemingly mentioned far more on the previous 2007MY vehicles, is it better not to take the risk of using the older part nos & just pay more to get Genuine / Delphi versions of the newer part no ?
Thanks in advance. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #461742 21st Dec 2017 10:28pm
GraemeS
According to my 2012 MCAT, LR018345 supersedes to RBX00200 which was the earlier part so perhaps LR018345 doesn't work as well as expected. However MCAT has some errors...
Edit 18th July 18. I must have been asleep when looking at MCAT as it shows RXB00200 supersedes to LR018345
Post #461750 21st Dec 2017 11:02pm
Pawl
GraemeS,
that's intriguing, via the LRDirect website , I saw that the RBX00200 bush was superceded by the LR018345.
The Russian (or Rumanian, not sure - lol) Microcat site I used didn't have any info on what superceded what.
You're info makes me even more unsure what to buy ! Paul,
Post #461751 21st Dec 2017 11:18pm
GraemeS
I just added a note to my post noting that MCAT isn't error-free so perhaps LR018343 LR018345 is still current.
LEMFORDER appear to make the genuine bushes and their picture still shows LR018343 LR018345 stamped on the bush.
Post #461752 21st Dec 2017 11:20pm
Pawl
None of the forum posts about suspension knock mention anything about LR changing the compression arm bush design, so there's no clue which may be better than the other.
The problems appear to have generated more discussion 6 + years ago.I don't know whether I dare conclude anything from that or not ? Eg later bush design is better ? Paul,
Post #461757 22nd Dec 2017 12:19am
GraemeS
I purchased my April 2012 build with 18k kms on the clock and its front suspension rattled then, but is slowly getting worse . It gets a hard time with its oversize tyres and lots of rough tracks/roads and it wont be too long before I replace those bushes in the hope that the rattle abates.
Post #461759 22nd Dec 2017 2:07am
Pawl
It's bad that you got the noises so early! I assume you decided to just accept it.
I need to change tyres soon, so I want to sort the issue before I change them as I'm sure having worn bushes isn't going to help tyre wear / life.
Thanks for the info confirming Lemforder are the OE supplier.
It seems easy to find Lemforder bushes alone, but a lot more challenging to find Lemforder arm assemblies. I'm not willing to pay dealer prices for them as they appear to be £160 or so each Shocked Paul,
Post #461798 22nd Dec 2017 10:54am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Is it a continous knock?
Mine does as exiting our park at steep uphill turning left,like smt is ticking on the wheel.
I could not make the knocking on level surface even how hard i turn or accelerate.
It does uphill and after 3/4 lock. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #461815 22nd Dec 2017 1:28pm
Pawl
Umitbat,
On our car, the noise is a single knock when the steering wheel is turned to near full lock at low speed.
The noise does not repeat until the opposite lock is selected - but then from the other side of the vehicle.
Your noise appears to be something different !
The fun of owning a Land Rover - always something new ! Paul,
Post #461818 22nd Dec 2017 2:27pm
umitbat
Pawl,Yes it is!!
She heard me and does on level turns too:)) 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #461848 22nd Dec 2017 7:45pm
GraemeS
Mine rattles going forwards or reverse over bumps including car-park speed humps.
Post #461856 22nd Dec 2017 8:21pm
A rattle is more likely to be the ARB control links👍🏻 Cheap and easy. There is nothing that can't be fixed with a hammer😜😜
Post #461862 22nd Dec 2017 8:35pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
my worst rattle was the driver side lower ball joint , knocked it tits off , the other was a rear arm bush on the same side but that was only at speed and while turning left
Post #461866 22nd Dec 2017 8:41pm
GraemeS
Its been a while but mine's rattle was caused by a floppy right side lower ball joint, the same as Bembo449's.
My Lemforder LR018345 replacement bushes didn't last 20K kms - they've split again and the car pulls and wanders under brakes again. I think they're not HD enough, too much designed towards providing a soft ride.
Post #524052 8th Aug 2019 1:17am
