Home > In Car Electronics (L322) > Cigar lighter fuse
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Cigar lighter fuse
Hi and a Merry Christmas to everyone.anyone know how to find cigar lighter fuse. my front rear passenger and cubby box all stopped working checked fuses in back and they are OK .Are they fuses 17 18 ? Noticed post saying number 1 all are 20 amp . Boot plug is working fine any ideas?
Post #461704 21st Dec 2017 7:19pm
front fuse box behind the glove compartment... ... - .- -.
Post #461705 21st Dec 2017 7:30pm
rik
Which fuse Stan ?Rear fuse box has cig lighter written on diagram but fuses are OK
Post #461706 21st Dec 2017 7:34pm
there should be a diagram on the fuse box lid ... ... - .- -.
Post #461715 21st Dec 2017 8:24pm
rik
Yes Stan there is no cig lighter on diagram in glove box only in rear but fuses are ok
Post #461730 21st Dec 2017 9:13pm
have a look in the WM..i thought it was fuse 52 ... ... - .- -.
Post #461731 21st Dec 2017 9:19pm
The fuses are on the rear fuse board.
If you sockets are normally ignition controlled it could be a faulty relay.
I'd post you a picture of the relay but for some reason I'm having trouble uploading it.
The relay is above the fuses, top left relay. Try swapping the fuse for another to see if it works. Thumbs Up
Post #461734 21st Dec 2017 9:45pm
rik
Will try relays tomorrow when it is daylight are all these relays interchangeable? Seems to be conflicting reports of which fuse 20amp ?
Post #461748 21st Dec 2017 10:43pm
@ndfi, i wonder where i got this from then, it shows fuse 52 for the front ciggy lighter..
Post #461773 22nd Dec 2017 7:38am
This is the fuse schedule for 2002-5 cars Stan, not quite sure what you have. Thumbs Up
Rear fuse board,
Post #461780 22nd Dec 2017 8:54am
Neutral
maybe 2006-2009....i really should label this stuff on my laptop.. ... - .- -.
Post #461782 22nd Dec 2017 9:01am
rik
OK guys got it fuse 1 left hand side of board 20amp put new one in and it blew straight away tried another and now no power to fuse any ideas
Post #461793 22nd Dec 2017 10:15am
rik
OK it's only just started working again strange but yeah thanks again
Post #461794 22nd Dec 2017 10:20am
Have a look in each of the sockets- it's not unknown for small coins etc to get in the bottom causing a short to earth. Thumbs Up
Post #461802 22nd Dec 2017 11:38am
rik
Hi thanks for all the help all good now .I can only guess how it blew sounds a bit bizzar but it's the wife's fault for shopping and keeping me waiting for so long.i was getting bored so started playing angry birds on a Nokia 6 whilst plugged in and charging . These phones are relatively new and have a big battery which can have a tendency to overheat which may in turn overheat the charger and blow fuse only overheats when playing games on phone . Also the charging plug with USB has stopped working.new one working fine.there must be a moral here somewhere if not a lesson not to go shopping with the angry bird ,😊
Post #461832 22nd Dec 2017 5:56pm
